Old 05-29-2016, 10:05 AM
reichsrundfu reichsrundfu is offline
Originally Posted by init4fun View Post
So I guess ya can call me "Mr. Some" , cause I always fully disconnect them , leave them in place , and then run the wires to a terminal strip holding the diodes (and if used , the dropping resistor) Many times , the same screw that holds the selenium in can be used to piggy back the terminal strip right there .
Exactly
I take em' out, mount them on little blocks of wood and use them as neat looking paperweights
Old 05-29-2016, 12:06 PM
I've got a couple of low voltage HIGH current bridge seleniums that are big'n'heavy enough to be paper weights without being mounted...
Old 05-29-2016, 07:47 PM
Moyers is filled with nos selenium rectifiers and I think they will sit for a long time.....there is a guy who stock piles them I wonder if he knows they are or will go bad...... never replaced them in Radios so its probably time to do so.
