Old 05-27-2016, 10:18 AM
Rich12 Rich12 is offline
Selenium Rectifier Question
I'm restoring a 1949 Emerson TV that has had some prior work done. As you can see from the pics 4 silicon diodes have been wired in. I can only pick up writing on one it appears to be an R170 which I believe is 2.5 amps / 1,000 volts. The soldering joints and connections look very well done. My concern is that they appear to connect in circuit with the existing 2 rectifiers instead of being detached? Also there is no additional resistor on the lines to the electrolytic's. I don't want to break it if doesn't need to be fixed? I'm a long way from putting this on a viac, I still need to replace numerous paper caps, electrolytic's and at least a couple tubes. Comments and suggestions are appreciated. Thanks!
Old 05-27-2016, 10:33 AM
I just read somewhere that it's perfectly acceptable to just place the diode across the Selenium rectifier, leaving it in the circuit, this is because Seleniums never short, they just go up in resistance until they fail.
As for adding resistance you'll need to get it running and check the B+ against the spec and adjust accordingly.
Old 05-27-2016, 11:04 AM
Selenium Rectifier
Thanks Eric!
Old 05-27-2016, 11:39 AM
Although some might consider it to be a "sloppy practice", I usually just bridge the seleniums with the diode... the original appearance is preserved and I have never had a problem.
Old 05-27-2016, 12:49 PM
reichsrundfu reichsrundfu is offline
Do so at your own peril! Suggest you disconnect one side of each original selinium. Ask me how I know this...... It was not a pretty event.
George
Old 05-27-2016, 12:56 PM
George
OK, I'll play... how do you know this?
Inquiring minds would love to hear "the rest of the story"
Old 05-27-2016, 01:09 PM
The selenium would see the peak inverse voltage, and after a while it may not take it any longer, and then start to conduct and then fail...
Old 05-27-2016, 01:16 PM
rca2000's Avatar
rca2000 rca2000 is offline
George
Been there...DONE that...many years back. i had a Motorola tv, 12LP4 tube..I was only 15 at the time...and still learning. Someone had ALREADY bridges the seleniums with diodes. but one of them STILL was smoking and smelling. So...I lifted the diode from one leg of the sel..and all was ok..
Old 05-27-2016, 02:49 PM
broadcaster broadcaster is offline
I always always lift one end of seleniums.
Old 05-27-2016, 06:20 PM
thanks everyone, I'm going to go the safe route and disconnect a side from each. I really appreciate all the input on this!
Old 05-27-2016, 06:29 PM
init4fun's Avatar
init4fun init4fun is offline
So I guess ya can call me "Mr. Some" , cause I always fully disconnect them , leave them in place , and then run the wires to a terminal strip holding the diodes (and if used , the dropping resistor) Many times , the same screw that holds the selenium in can be used to piggy back the terminal strip right there .
Exactly
Old 05-27-2016, 06:30 PM
Bridging a selenium with a Si diode does not mitigate the effect of reverse leakage in the selenium. Heating due to reverse leakage increasing is part of the failure mode (in addition to heating due to increased forward resistance). Always take the selenium out of circuit.
Old 05-28-2016, 01:41 AM
A compelling reason that I had not considered... thanks guys!
Old 05-28-2016, 03:39 PM
Other then that they smell bad when they go sour.
Old 05-28-2016, 04:58 PM
I've only replaced the Seleniums in a few sets, most of the time they still work satisfactorily.
I know there's a risk of a stinky failure but as often as they get used it's pretty low.
