Old 11-02-2019, 04:03 PM
Originally Posted by mr_rye89 View Post
Lookin good so far. I have a few 6080s/6AS7s left over from my OTL headphone amp days if you want them.
I probably don't need them, but if you want them gone I don't mind being the custodian of them.
Originally Posted by kf4rca View Post
You can build a TV dolly fairly easily, out of two 2x2 pieces of plywood and a 2x4 and some casters.
I have some low furniture dollys that I could used for that purpose if I had something the right height to stack...I just don't have any time for woodwork presently (also I need an adjustable height cart with a lift jack not fixed height)...Hell I probably lost a good 2 hours per night of sleep per night just to get that Conrac buttoned up. It is together and resting on a packard bell console now so it is safe.
Is frame number 4 a picture of a lady in a shower lol ?
Radiation decontamination actually....I take it you haven't seen the james Bond Film 'Dr. No' before...
Before I turned down the B+ to spec it filled the screen and was running 235mA H out cathode current and the fly was gettign hot after 40 min running. After getting B+ to spce it was running 180mA, but didn't fill the screen. I then subbed a better tube and currently have the compromise fo full screen and 220mA (cathode current had to be adjusted off dip for a full screen)... H centering is at one end. which don't help...I may in the future try to get it better.
For now it is good enough that I can try to work on other stuff and get unburied in projects.
Old 09-15-2020, 08:39 PM
vintage.digi vintage.digi is offline
Did anyone manage to locate a scan of the service manual for this monitor? I'd imagine that the one for the CYA would also have quite a bit of overlapping information.
Old 09-16-2020, 10:57 AM
The one Kf4RCA posted is correct and all I have presently....The set was working fine when I last used it the last time this thread was active so I'm not worried.
