Old 09-20-2024, 08:26 PM
Chris K Chris K is offline
I don't want to remove the coil from the chassis if I can help it. I can see the top and bottom of the core. The top of it has a slot, the bottom dies not and there's a little debris I cleaned out from what broke off. Very difficult to photograph but the core is intact...I just have to get it out and screw it in from the bottom
Old 09-20-2024, 08:35 PM
Here is a photo of the bottom with it run all the way down. The only think that broke was the parts of the core on the sides of the slot.
Old 09-20-2024, 08:47 PM
Penthode's Avatar
Penthode Penthode is offline
I always use a hard plastic tool to adjust the cores. Try and refrain from using a metal tip because unless the tip fits snugly, the uneven sape will imose high stress to the brittle slug slot wall. I carved a hard plastic rod to the shape of the slot.
You can see the slot the other end? I would gently try and screw it downward and out. Do not force it if it jams.
If the core only has the slot damaged one end and is otherwise okay, I would simply flip it 180 degreses and put it back and continue the alignment.
Old 09-20-2024, 08:49 PM
Penthode's Avatar
correct that, I didn't recall the brass ring obstruction. Remove it from the top seems the only option.
Old 09-20-2024, 08:51 PM
I agree...slowly turning it out with a plastic flat blade tool.
Old 09-20-2024, 09:07 PM
I cant get it out the top. I can feel the slot starting to go. I looked down into it very gently blew the threads clean and the debris out and I think it's coming up as far as it's going to go without breaking it. So I think I'm back to replacing the coil or getting this core out and finding a substitute. From what you've tald me about this TV, that's probably not going to work.
Old 09-20-2024, 09:16 PM
I have an entire parts chassis out in the garage. It probably still has this coil
Old 09-20-2024, 09:28 PM
Wow. If you could check and let me know I would so appreciate that. You can email me Bob
Old 09-20-2024, 09:31 PM
Penthode's Avatar
That is good that spares are available. But with a bit of judicial manipulation and patience, let us try and remove the core. The worst thing is you simply have to replace the slug.
Have you tried a bit of heat to melt the wax residue?
I have never had to replace one of these transformers. They are fixable.
Old 09-20-2024, 09:44 PM
Were not those donono mica capacitors that was shown in the above pic a source of trouble in these sets?
Old 09-20-2024, 09:47 PM
Penthode's Avatar
Funny talking about HP8601a's, I found another one locally on FB Marketplace today. It came from the estate of a local engineer.
There was a whole pile of high end HP and Tektronix test equipment from the 60's thru the 1980's. I wanted only the Tektronix 2710 Spectrum Analyser and the HP8601a and offered C$120. The seller wanted to dispose of the lot which included a second Spectrum Analyser with tracking generator, a few high end older Tektronix scopes, an HP 8640 HF to SHF sweeper generator, a huge pile of Tektronix plug in modules Tek digital multimeter, frequency counter, low frequency function generators, a three foot desk equipment rack scope probes and a nice looking Wavetek Sweeper with marker option. All for C$200.
Maybe I can dispose of the surplus stuff to pay for the HP8601a and the Tek 2710 Spectrum Analyser?
Old 09-20-2024, 10:18 PM
If Bob can locate a replacement for me, I’ll try just for the experience.
Old 09-20-2024, 11:54 PM
Penthode's Avatar
Good question. I have found one bad but I generally haven't had much trouble with them in these sets. I would be curious if others have.
Old 09-21-2024, 01:38 AM
I believe bandersen mentioned something about them before. yes, namely the 270pf caps.
Old 09-21-2024, 11:06 AM
Yes, I've sometimes needed to replace the 270pF mica caps that couple the IF stages. However, it looks like you are getting a good image so I would not be concerned about them.
