Old 07-24-2010, 04:53 AM
RitchieMars's Avatar
RitchieMars RitchieMars is offline
VK Member
Well, thanks for trying! If that tester can pull off that re-weld techique, it would be worth a try, but even then I know some tubes just are beyond repair.
Well guys, just keep the word out for me. Maybe I'll put out some WANTED posters...
Old 07-24-2010, 07:13 AM
tvdude1 tvdude1 is offline
crt
I have a new zenith 17cqp4 in the box if you think it could work you can have it for the shipping.
Old 07-25-2010, 12:30 AM
VK Member
That sounds great! It may take me a little research ( and some knowledgeable advice ) to figure out if this will work, though. I haven't found info on a 17CQP4 as of yet, but I've found specs on the 17QP4 which I suspect is closely related.
http://www.shinjo.info/frank/sheets/093/1/17QP4.pdf
Here's the good news! Physical specs are nearly identical! I believe the faceplate is the same shape and size, the neck is the same length, same overall length. Everywhere I see where it would matter, it should definitely fit my chassis and yoke. Electrically, the specs are almost identical to the 17LP4.
But, there are a couple of notable differences. There is one pin that the 17LP4 uses that is missing on this 17QP4, pin 6 (G4). It also states that this tube has magnetic focus instead of electrostatic focus. I honestly don't even know what that means, so I have no clue as to how interchangeable these two types are or what changes would need to be made to make one work in the other.
Does anyone have some specs on the 17CQP4 for comparison? I can't assume the 17QP4 is the same, and I don't know what the "C" in there indicates.
Old 07-25-2010, 12:42 AM
VK Member
( double post ) I dunno how to delete it... lol
Old 07-25-2010, 01:15 AM
Magnetic focus uses an external magnet assembly, either electric or mechanical to focus the tube, electrostatic focus uses voltage to focus it internally inside the gun, that's probably what the missing pin is for.
You might get lucky and have it work without the magnet assembly but probably not.
Old 07-25-2010, 01:42 AM
But it might be possible to add a magnetic focus coil or permanent magnet assembly salvaged from another set to adjust focus on this tube. Years ago, I used an aftermarket add-on permanent magnet focus assembly called a Quam "focalizer" (or something close to that) to focus a crt in a set where the focus coil had failed... something like that might work.
Old 07-25-2010, 02:47 AM
VK Member
Right, I was thinking that. I wonder if this worked like it does on an electrostatic speaker where the magnetic field is created by current flowing through a coil, which would means the coil would have to be tapped into a circuit somewhere. Obviously, a permanent magnet would be much easier. I'll look into this a bit...
I'm still unsure about this type of tube and I wish I could find some specifics on it. I'd hate to pass up a NOS tube. In my opinion, changing to a magnetic focus would be an improvement over the electrostatic if it were possible. With the electrostatic type, I understand that the focus degrades over the life of the tube.
Old 07-25-2010, 01:40 PM
Here are a couple of pix of a permanent magnet focus assembly (mounted between the yoke and the ion trap) in my 1953 Philco... it would take a fair amount of mechanical modification to support such an assembly in your set, but it might be worth a try if you can't find the correct CRT. The focus adjust is the little brass knob on the flex shaft, shown on the second picture. The little lever, with the wing-nut lock at the top of the assembly is the position adjuster.
The Philco uses a 17YP4, which also has a cylindrical face.
Old 07-26-2010, 11:38 AM
I have at least one spare PM focus assembly, if you needed it. I agree that it could be difficult to fit, depending on how the yoke is arranged.
Old 07-26-2010, 01:33 PM
leadlike's Avatar
leadlike leadlike is offline
I might have a spare assembly as well. It is a large ring magnet, so you don't need to make an electrical connection to it. It came out of a tv that I got a new crt for, and I had to change it from magnetic focus to electrostatic, which is much easier to do (just rip out the old m-focus hardware). If you need it, I'll see if I still have it.
Old 07-27-2010, 02:29 AM
VK Member
For the time being, I guess I have time to decide which route I want to go. It would suck if I had the tube and magnetic focus assembly shipped to me only to find out that neither will actually work out as planned. I believe there's a good chance that it would, but as I yet I still can't find the specifics on this 17CQP4. I've only read about the 17QP4, and I have no idea what the "C" stands for.
It should be a little while before I get the set recapped and ready to test again, and hopefully my CRT will be adequate for those purposes. I'm rather afraid to jump at such a tempting but risky chance when for all I know, a good 17LP4 might turn up somewhere the day I'm sitting here scratching my head over how to install this magnetic focus assembly. That would be just my luck!
Just curious, what would be the best route to safely ship an 18-pound CRT this size and what would it cost?
Old 07-27-2010, 02:27 PM
Are you sure it's not a 17CGP4? I ask because I don't see a CQP4 listed here:
http://tubedata.milbert.com/sheets14.html
The CGP4 is quite similar to the LP4 but is two inches shorter.
Old 07-27-2010, 05:48 PM
VK Member
Nah, I've seen mention of Sylvania tubes such as the 21CQP4. Oddly enough, that particular tube uses electrostatic focus. The 17CGP4 there doesn't look like a cylindrical face plate, but it's also an electrostatic focus. It would be so nice if that "C" stood for an electrostatic version of the 17QP4. I'd be pretty sure it would work if that was the case. I'll check into this, but I rather doubt that's what it means.
Old 07-27-2010, 07:54 PM
I'll look tomorrow as I have several NOS 17" tubes. That number sounds like one I have.
julian
Old 07-28-2010, 04:42 PM
VK Member
Alrighty, let me know what you've got. A proper replacement would make life so much easier than the modifications I'd considering. The following should be drop-in replacements:
17LP4
17VP4
17LP4A
17VP4B
There may be more, but these are the most closely related.
