Old 07-17-2010, 07:04 PM
RitchieMars's Avatar
RitchieMars RitchieMars is offline
VK Member
17LP4 CRT ( Need one... )
After removing my CRT and cleaning around the neck, I could clearly make out the crack you see in the photo I've attached to this thread. After closely examining photo's made prior to this, it appears that this crack was present all along and probably even before I brought the set home. The very dim picture along with this crack around the neck is enough to qualify this as a "bad" CRT, in my opinion.
If I am to bother trying to repair this set as intended, I will first have to find a suitable replacement 17LP4 ( or 17VP4) CRT. I'm not sure how many of these are around or what one will cost me, but if nothing turns up, I'm afraid this will force my Zenith into retirement as nothing more than an interesting piece of furniture.
Old 07-17-2010, 08:54 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
If the phosphor, screen, hasn't been disturbed then Scotty should be able to rebuild it. Time is short though.
Old 07-17-2010, 09:17 PM
Short is right. Next week is it for Scotty
Old 07-17-2010, 10:08 PM
VK Member
Next week? That would really be calling it close for me. Is this fellow retiring or something? How could I get ahold of him, assuming could get my CRT to him in time? I live in South Carolina, btw.
Old 07-17-2010, 10:14 PM
Yes, he's retiring. Here's an article about Hawkeye and here's the website.
Old 07-18-2010, 01:22 PM
jeyurkon's Avatar
Those are pretty impressive cracks. It's difficult to imagine that the tube hasn't gone up to air, but yet you say you still get a dim picture.
What does the getter flash look like? Is it still shiny?
Rebuilding is expensive and if you can get an NOS one, then if this one works well enough to keep you busy restoring the set, then I suppose it makes sense to use it until you find one.
Old 07-18-2010, 02:36 PM
marty59's Avatar
marty59 marty59 is offline
Just my opinion on your tube...I'd agree about trying to find another one. Even if you shipped the one you have (cracked) the handling and shipping of something that is just more fragile may not make the trip.
Old 07-18-2010, 05:42 PM
VK Member
If the "getter flash" is what I think it is, it's shiny. All of the visible parts of the beam gun look almost like chrome, aside from these 3 transparent cylinder things.
The light I could see coming from the neck of the tube when it was in operation was fairly decent, brighter than any of the other tubes. At night in a dark room, I could adjust the ion trap to get a full raster, bright enough to cast a glow a few feet from the tv. Turn on the lights, and it's practically nothing. I was able to get something of picture, at one point ( in the dark, of course ) although the images flipped and scrolled, and went slanted into chaos. Aside from this, I've also never gotten any sound other than a very small crackle from the speakers and I only heard this once or twice as the tv warmed up.
With the dim picture, I'd assumed that the CRT was bad all along but I didn't know about the crack until now. But, I also knew it needed caps and probably a couple tubes so it hasn't been turned on for months. Right now it's been taken apart ( there was no spark when I discharged the CRT ) and it's got a nice, clean chassis after I went through it last night and this morning.
I've already located a company that sells new 17LP4's, but it would cost $185. It would be oh, so very nice if I found one a bit more affordably than that. For now, I'll get my schematics, recap it, and test it with what I've got. I'll just pay attention to my CRT when it's running and see if it smells like ozone near the back...
Old 07-18-2010, 08:23 PM
If the company is Video Display Corp then most likely they don't have one, they list most every type but when you inquire they'll tell you it's a database error.
There was a NOS 17LP4 listed on eBay a while back for $25, don't know who, if anybody got it.
Old 07-18-2010, 08:30 PM
VK Member
Yeah, VDC is the only one I found. If they didn't have it, then I guess it wouldn't be worth worrying about. It's expensive, anyways. I'll write them and find out, just to be sure. I saw the one for $25 and I think it sold. I ran across a thread about it here that was posted in the past year or two.
Old 07-18-2010, 08:59 PM
Just for grins, I have posted a picture of a CRT getter flash... It is an evaporated coating of barium deposited on the inside wall of the glass, to "pump" residual gas after the CRT is sealed. In this tube, the gun parts also look fairly shiny, but that is not what you are looking for... the getter flash is visible through a small rectangular window in the gray dag coating. It is shiny, and in this tube, exhibits some "rainbow" color around the edge.
Note: this tube uses cream colored ceramic supports for the gun elements, rather than the clear glass support rods seen in your CRT.
Old 07-19-2010, 12:34 AM
VK Member
Hmmm... in light of this information; is my getter flash still shiny? Eh... not so much...
What do you guys know about the interchangeability of CRT's? The one in my television was originally a 17LP4 and/or 17VP4. Are there any other compatible 17-inch CRT's that might interchange? If so, I'll have to keep a look-out for those also. So far, I've read about a couple different variations made during this period that are very similar to the 17LP4. The main difference I've noticed is that my CRT is uses an electrostatic focus, and many of the other types are magnetic. However, the 17RP4/17HP4 has nearly identical specifications to the 17LP4, and also uses an electrostatic focus.
Here's the specs for the 17LP4:
http://www.shinjo.info/frank/sheets/137/1/17LP4.pdf
Oh, and below is my not-so-shiny getter flash.
Old 07-19-2010, 12:57 PM
grimer's Avatar
grimer grimer is offline
I have a 17lp4 that I do not need,it is stored in a plastic bin behind my garage.
Probably be able to get it out and test it this weekend
Pat
Old 07-19-2010, 01:55 PM
leadlike's Avatar
leadlike leadlike is offline
Look at your getter, it looks like it has been "got".
Old 07-19-2010, 03:10 PM
If you don't have a crt tester, there is an easy way to determine if the tube is very gassy. IT IS A DESTRUCTIVE TEST IF THE TUBE IS VERY GASSY!
1. measure the heater resistance... should be fairly low, like a few ohms.
2. apply 6.3 volts to the heater (Pins 1 & 12)... does it light up normal brightness? if so, the CRT may have a decent vacuum in spite of the crack and "used up" looking getter.
3. if it just barely lights up, it will likely burn out very quickly, perhaps you will see a flash. Tube is very gassy and now has a burned out heater.
4. re-measure the heater resistance... if the tube is very gassy, it is now likely "open".
Here is what happens...the heater resistance is much lower when it is cold than when it is hot. If the tube is gassy, air molecules will transfer heat away from the heater, so it will remain fairly cold. Since the heater resistance stays low, it will draw more current than it is rated for, and open up like a fuse.
Even if the tube is very gassy, continue to handle it carefully, as it still could have a partial vacuum, and be an implosion hazard.
