Old 07-22-2016, 08:41 PM
Radiotronman's Avatar
I've got a yoke/flyback transformer, but I've never tested a yoke before. Any tips on how to test this yoke? The CRT tested ok on my tester, so I'm thinking there's something wrong with my yoke.
Old 07-22-2016, 08:58 PM
Do you mean a yoke/flyback tester?
If it's a vintage tester, you can find many equipment manuals at BAMA:
http://bama.edebris.com/manuals/
Regards,
Old 07-23-2016, 01:36 PM
I think I may switch the CRT from my holiday to my barberpole since it's worth the most. I'll search for a new 21fdp4 for my holiday and hopefully find another some day. My barberpole I play on having and watching in my living room too.
Old 07-23-2016, 10:51 PM
The wire that connects the grid cap to hv rectifier broke off at the flyback...I had an nos one so I dug down a little and soldered it on. The flyback has to be recoated anyway and I have rtv 4165 I believe. Is that suitable? I believe when I bought it, it was rated for 15k+ volts.
Old 07-25-2016, 09:06 AM
I did a google search for RTV 4165 and came up empty. Are you sure that's what you have ?
Old 07-25-2016, 05:52 PM
Angry
I'll look and see, I may be wrong. A 1 watt resistor in the tuner also over heated, not sure why. I got the video to work, but now I only have a white raster. Not sure where my video is lost or maybe my tuner is bad?
Old 07-25-2016, 06:56 PM
It is Dow Corning 3145 rtv sealant.
Old 07-25-2016, 10:13 PM
This is what I'm getting now with a DVD player. Like I said above, I had pretty good video earlier. What happened?
Old 07-25-2016, 10:27 PM
Forgot the image...
Old 07-29-2016, 03:43 PM
After a little help from another Predicta restorer, I found out that the black plug from the tuner to the main chassis, can be plugged in more than one way. Only one way works right! I've got my video working again, but now I'm trying to figure out where my interference is coming from?
Old 07-29-2016, 04:49 PM
What is your source? (DVD player, VCR, etc.?)
Phil's Old Radios
Old 07-29-2016, 04:56 PM
A low grade DVD player and its hooked up by jumper cables to a 300ohm coax converter. So plenty of areas for interference. I'm going to hook up a digital converter box straight to the tuner and see if it's better. Btw, if anyone needs any Predicta parts or tips on restoration, I would definitely recommend Larry Whitlock. He's been restoring predictas for years and has extensive knowledge on these complicated sets. He's given me a lot of invaluable help with the last three predictas I've restored!
Old 07-29-2016, 05:20 PM
+1 for Larry Whitlock!
Old 07-30-2016, 09:09 PM
El Predicta El Predicta is offline
Thanks guys, glad I can help.
Old 07-31-2016, 11:02 PM
Ok guys, I think I'm calling this Predicta done! I'm going to get some new brass plated screws that look like the originals, to hold the back on. The originals are a little rusty. Also I'm waiting on a replacement on/off volume on from Larry.
