Old 10-23-2019, 03:55 PM
It can be a defect in the audio circuits of the set, excessive signal strength, or a consumer grade RF modulator putting out a signal that has audio interference. How do other tube era TVs handle your modulator?
Old 10-23-2019, 07:25 PM
static1701's Avatar
static1701 static1701 is offline
All of the other TV's work fine with the modulator. When I took the Predicta into the house, I hooked up a DTV converter to it, using ch3 . My modulator uses ch10. The sound is perfect unless text is on the screen. The little logo text does not cause a problem, just the titles and stuff like that. I can adjust it to some degree with the fine tuning control but I can't get rid of it.
Old 10-24-2019, 01:04 AM
Also can be an IF alignment / sound alignment problem.
Old 10-24-2019, 09:18 AM
judge's Avatar
judge judge is offline
FWIW my predicta has the same issue. It can be ameliorated somewhat by adjusting the fine tuning. I have heard that a possible issue is that extreme changes in contrast create signals that are picked up by the audio section. Sorry, that is very vague. Worth googling the issue though.
http://nixies.us/
