Old 12-29-2022, 09:20 PM
What do you mean by “fried” and “baked”?
Old 12-29-2022, 09:48 PM
Chris K Chris K is offline
No emission...zero
Old 12-29-2022, 09:54 PM
Do the heaters lite up on the zero emission tubes?
Old 12-30-2022, 07:17 AM
I don't know but...in the absence of any good 12AT7 tubes, I substituted 3 12AU7 tubes, not a good direct replacement but good enough to check function, and things are back to semi normal function. I suppose something transient caused the issues, not a persistent connection problem or a wiring issue. The tubes now all light up and there's light on the screen. Sorry I pulled everyone down a rabbit hole.
Old 12-30-2022, 11:16 AM
Obviously lots of work left to do and I'll wait for the correct tubes but we're back online again.
Old 12-30-2022, 01:22 PM
That's good to see.
You need 12AT7 or IIRC 12AV7 for RF/Osc/IF applications(the capacitances and such of the AU/AX are too different), but the 12AU/AX7 will basically work close to audio frequency.
Old 12-30-2022, 04:18 PM
Make sure the b+ is where it should be. mine no matter what I did couldn’t get the b+ right so I put a 1n4007 across the positive rectifier tube that fixed it.
Old 12-30-2022, 08:45 PM
Looking promising! Any clues/theories as to what caused the big transient?
Old 12-31-2022, 01:04 PM
Yeah I'm always very careful to have power switch on the unit off and the Variac/Dim Bulb setup all powered down and shut off when I plug in the unit but I didn't have everything in that configuration so when I plugged it in there was a flash...that was the 3 ohm resistor in the string blowing and the tubes getting whacked. Or it was when I unplugged it in the same condition. Can't completely remember but it was not while the TV was in operation.
