Old 10-06-2003, 01:42 PM
polaraman's Avatar
<--1956 300B
.068MFD/1000v cap
Where do I find this .068MFD @ 1000 volt capacitor? Working on my 1951 Stromburg - Carlson Chinese Classic TV. This is the last cap in the HV section that I need. With 28 tubes in the set it is going to be awhile!
Polaraman
Old 10-06-2003, 02:59 PM
PaulC
Guest
Posts: n/a
ASC makes a .068@2000v PN225-6180 at Allied electronics. http://www.alliedelec.com/catalog/pf.asp?FN=144.pdf
Someone else may supply them without a minimum order.
Paul
Old 10-06-2003, 03:34 PM
gonefishin's Avatar
gonefishin gonefishin is offline
Banned
you can check these guys out on the web...although...if they don't have the item listed online...I would still give them a call. They've got a ton of stuff!
good luck!
Old 10-06-2003, 05:22 PM
ChuckA's Avatar
ChuckA ChuckA is offline
You can get .068 @1600v for $0.95 from www.justradios.com but his minimum is $10. and shipping is $2.90.
Chuck
www.myvintagetv.com
