Old 02-24-2007, 03:19 PM
keith6989 keith6989 is offline
Philips 725 Blows Tube
I have a tube radio that I replace the caps in, now when you turn the radio on from cold the 6aq5 tube wil arc snap, and loose it's vacume, I cant figure out why it would do this... Anyone have any ideas?
Old 03-04-2007, 11:12 PM
LDK180's Avatar
LDK180 LDK180 is offline
befuddled
First, I'm going to assume you replaced ripple filter (power supply cap).
Did you replace it with the same value cap, and did you install it with the polarity correct?
