Old 10-09-2003, 08:35 PM
Cory's Avatar
Cory Cory is offline
Cory Heisterkamp
8PT Hum bar
Hey guys, I've got a slight problem I thought someone might have a clue to. I just finished recapping one of those RCA 8" 8PT metal sets and have a great picture and sound. Works great. Except, I detect a very slight hum bar that rolls upwards, maybe an inch or two in width. Playing with the fine tuning I can invert the bar with respect to the picture (it's a very very light bar, most noticeable on a dark picture). I can _almost_ tune it away. Tuner tube shields are in place.
Any ideas?
TIA, Cory
Old 10-09-2003, 11:34 PM
Rob Rob is offline
Banned
Is that a series string filament set with no power xfmer? The fact that it is a single hum bar and not two means that the hum rate is at 60 Hz while the vertical scan rate (off air color signal) is at 59.94 Hz. Hence the slow roll. A heater to cathode leak/short in one of the tubes in the video chain or CRT would give you two hum bars I would think. A single bar I'm thinking may be power supply hum from a half wave voltage doubler supply. Bad electrolytic? I've none to little experience with series sets so maybe one of the experts here can chime in.
The fact that it inverts with fine tuning adjustment... That sounds like the hum bar is in the RF signal. Try replacing the RF amplifier tube if you have one in the tuner. Check the RF signal source with another TV. Maybe your cable company is sending you this hum bar.
