Old 10-26-2003, 07:26 AM
geojunkie
Guest
Posts: n/a
2 Cap Questions
Question 1:
I recently restored an RCA 14PD from the late 50s that used vertical paper and molded caps mounted on a circuit board. Both leads are out the bottom. I ended up using axial polys and running one lead down the side. Great for servicing (you can attach test leads from on top on board), but doesn't look very original. Is there a source for replacement vertical mounts? If not, are there some other ways to tackle this?
Question 2:
The audio output transformer section of a tube radio (German early 60s) has some 1000v molded paper caps. The B+ supply to the plate of the output tubes is 275v. Do I really need 1000v caps and if so, where do I find them besides as ceramics?
Dan
Old 10-26-2003, 03:09 PM
Chad Hauris's Avatar
Yes, you need 1000 volt caps across the audio output xfmr primary because there can be inductively-induced voltages across the transformer that are higher than the DC voltage, especially if the speaker is accidentally disconnected. I do believe there are 1600 volt mylar caps but cannot recommend a source. Ceramics would probably do the trick though.
I have seen 1960's equipment that uses axial caps and runs one lead down the side of the capacitor on a circuit board, personally I don't think it looks so bad. I have never seen radial-type modern mylar/polystyrene caps.
