Old 04-25-2007, 01:19 PM
radotvguy radotvguy is offline
mike g
radio question
Ok guys , i got a question . I have have a zenith bakalite table top radio from 1950s. It is am/fm . My question is it has several 220ohm resisters in it . These resistor are white and green . The schematic reads this value also . Can i replace these with regular carbon resistors . They are located in IF circuit .
Old 04-28-2007, 01:55 PM
Reece's Avatar
Reece Reece is offline
Without seeing the schematic, I would say you can replace them with carbon resistors. But how do you know that they are bad? Usually just replacing paper caps and electrolytics in a radio of that era will get it going again. Are you sure they are resistors? There were some capacitors that sort of looked like resistors used back then, that are generally quite reliable and should not be replaced. Does the radio operate at present? Do you have a schematic?
Reece
Reece
