Old 07-09-2007, 06:54 PM
Kaztronic
Guest
Posts: n/a
Sentinel Tabletop
Hi Everyone,
A few months back I bought my first tube radio, a Zenith K731. I'm glad I started with that particular radio as it sounds great, and does a real good job pulling in stations. Shortly after buying her, I found your forum and put up a few posts about the radio, seeking general information and thus I was hooked on radios. I'm up to 12 tube radios now, and have a few more on the way. I once again have questions, and I am hopeful that some of you can point me in the right direction.
Like my first radio, the K731 most of my radios are not restored and still have the original caps and resistors inside. The K731 has gotten a lot of play time, and remarkably still sounds perfect, no hum at all, and still a reception champ (although not quite as strong as my Superadio III - a guilty pleasure of a radio that lets me tune in C2C on Fridays when it's not on in my area). The other radios, not too much play time. I have reached the point that I am ready to learn about restoring radios and want to get these old gals back up to full speed. I'm going out to buy a soldering pencil, and a multi-tester this week, and will begin doing the research on what parts I need to buy to repair these radios. I must admit, I have no soldering experience, and have never attempted anything like this before (I do have tons of patience though, so I think that will make up for my lack of experience). Any basic tips to start? Am I getting in over my head?
I also have a few specific questions, and would like to detail the radios I have, and their present condition to see if you could advise me on which one to start with (although I think I am going to start with the Sentinel as I basically bought it for that purpose, but it may end up needing more work than the others after todays little experiement).
1. Zenith K731 - Simply put, there is no way I am starting with this one. She works great, and as my first, it is also one of the most precious if not my overall favorite. As the radio that started this hobby for me, she deserves a true tune-up when I have some idea of what I am doing.
2. GE model 200 Bakelite - No hum, volume seems a bit low, especially at the lower end of the AM band - what causes that? The volume is half as high in the 600-800 range as it is up around 1000-1200. Otherwise works great, tuning is accurate and reception seems OK, although a bit weaker than all of the others.
3. Admiral 6T01-6A1-IV (also a bakelite radio) - Works great, no hum, accurate tuning, very good reception. The only knock on this radio is that you can barely see the thin tuning needle when the backlite is on, and the tuning knob is both tight, and sticks a bit.
4. Dunlop radio from 1936 - This radio is simply beautiful and has shortwave and the police band, the only one I have so far with shortwave. I bought it "restored", but within a couple weeks I heard a popping sound and since then I mainly tune in chirps and whistles on AM. Also, the tuning is sticky, and the tuning eye always seems to be fully lit up. Reception is quite weak even when it was restored. (This is another radio I don't want to start up with as it is the most valuable one I own and by far the best looking).
5. Arvin 35R48 tabletop radio - This one has a little bit of hum, although not really noticable and while it pulls in great on AM, it is basically deaf on FM. What causes a radio to be good on one band, but deaf on the other? Similar problem with the Sentinel radio I am going to list next.
6. Sentinel wood table top radio (model unknown, schematic and all other labels missing) - I just received this one today, plugged it in and it worked great on AM. No hum, great sound, good reception. FM was totally dead. I noticed that the lightbulb was not installed, so I went and bought one for it, plugged it back in and heard what sounded like a circuit breaker go off and that was all she wrote. None of the tubes are lighting now and the radio seems dead. This was the radio I bought to make as my first repair unit, now I am not sure as it is the only one I have that is not working at all.
7. Finally, the last one I want to restore - GE model 102 another bakelite radio. This one worked fine for about half an hour, after which time the audio became distorted and lower and sounds lousy now, in fact hard to make out the words. The dial light is also out of operation.
So, sorry to have typed out such a long post here. I am wondering which you would advise me to work on first, any particular books I should buy to help guide me along the way, and also any help you can give me in explaining some of the specific problems listed above would be greatly appreciated as it will help me to better understand how these radios work.
Many thanks in advance, oh, and I've got pics of all these radios and would love to share them sometime but am unsure about how to post them here.
PS - I thought I should mention my favorite radio as well. An unknown model number Silvertone dual speaker AM tabletop radio. I bought it fully restored, and it sounds wonderful (similar to the K731, although not as bassy, yet perhaps a little more clear). The reception is great, and it has the best looking dial I've seen yet with the red lettering and all. Sadly it arrived in pieces, but I wanted this one so bad that I glued it back together and kept it. I use this one on a daily basis to listen to Coast To Coast
Old 07-09-2007, 07:10 PM
Kaztronic
Guest
Posts: n/a
Model number addendum
Oh, I figured out the model numbers for the Sentinel radio, as well as the Silvertone that I am in love with.
The Sentinel radio is a 294-T
The Silvertone is a 7013 (If anyone ever sees a perfect case for this radio, please let me know
Old 07-09-2007, 07:23 PM
You REALLY need to save up yr nickels 'n' dimes, & get yrself a Hallicrafters SX-62 or 62A. They cover BCB-AM band- thru 109 Mcs, so you can get the FM band, too. Plus ALL the shortwave bands. The case on 'em was designed by Raymond Loewy, the same guy who designed the postwar Studebakers. They have EXCELLENT sound, enuff knobs to keep you busy twiddlin' them (Altho you don't have to), & there's no "Unobtainium" tubes in 'em. A decent one will set you back about $350-400 on You-Know-Where. I REALLY, REALLY like mine-they're big, pretty, VERY substantial looking, have an "old, yet modern" look about them. You boys thought I was gonna try to sell him on an R-390A, didn't ya? Well, Bunky, that can be yr NEXT one...After the SX-62....<grin>
Old 07-10-2007, 12:54 AM
radioactive's Avatar
radioactive radioactive is offline
tube gear fanatic
well it would'nt be the first time you tried to sell someone on a r390-a .i myself would like to get my hands on another sx62a and say the matching tv set now that would be a interesting set of gear.
real radios glow in the dark...
Old 07-10-2007, 02:20 PM
It is the SX-42 (not SX-62) that is designed like the Hallicrafters T-54 television.
http://antiqueradio.org/halli07.htm
Raymond Loewy is often credited with this design, but I read somewhere that it was created by his company (i.e., some drone on his staff), not him personally.
A cool radio/TV pair, either way. I own a model 505 TV, which is the same television in a mahogany cabinet:
http://antiqueradio.org/halli505.htm
Phil's Old Radios
Old 07-10-2007, 05:24 PM
Kaztronic
Guest
Posts: n/a
Hi All,
Thanks for the advice about the Hallicrafters. Unfortunately most of the Hallicrafters are not currently in my budget, other than the S-120 (which I wont buy based on everything I've ever heard about it), and the S-38, which I definitely intend to purchase at some point in the future.
Right now, rather than buying more radios, I want to turn my attention to restoring several of the sets I have now and would really appreciate any general advice, or even specific advice based on the radios I've described above
Thanks, and I'll let you know when I get my first Hallicrafters
Scott
PS - I think the next radio I am planning to buy is actually a Lafayette HA-600. I have been looking and waiting for a nice one of those for a while.
Old 07-11-2007, 11:23 PM
Nolan Woodbury's Avatar
Nolan Woodbury Nolan Woodbury is offline
Shaken, not stirred
Hi Scott,
Although I've been around antique electronics (hmm...antique everything would be more accurate) my whole life, I was in your shoes about three years ago. Since then I've recapped/repaired/restored several sets. I've destroyed a couple too...well, ruined beyond my ability (or patience) to fix anyway. It happens.
There are many radio books, but I purchased "Antique Radio Restoration Guide" by David Johnson (ISBN 0-87069-638-6) read posts and websites, and tore a few radios down. The book helped not only my understanding of how a radio works, but also which tools and supplies I'd need. All the info for paper capacitors (your first priority) electrolytics (second priority) and rectifiers (third) is listed in the book, and available from the advertisers here at AK. I use AES in Tempe, AZ; about 1-hour from my house. Tom Bavis here at AK is a great source for schematics.
After you've rooted around for awhile, it'll be easier to ask, and answer questions here, as a lot of these guys have been at it for a long time.
Nothing replaces experience though, so tear one apart and get learning! It's a fun hobby, I really enjoy it-
Bedroom: Marantz 2015 / Pioneer CS-88
Living Room: Zenith Y928 / MJ 1035 vintage stereos
Office: Zenith H845
Home desk: Zenith X338 / H272W Circle of Sound
Truck: Kraco Dust-O-Matic, circa 1977
