Old 07-15-2007, 07:41 PM
EVBoy EVBoy is offline
Magnavox find
Nice old Magnavox from an estate sale. I wasn't going to buy it but nobody wanted it so I couldn't let it go to the dump. Weighs a ton with a beautiful wood cabinet. Works but not like it should so it will be a project.
Old 07-15-2007, 08:10 PM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
Looks like a field coil woofer(?).
all the best,
mrh
Old 07-15-2007, 08:25 PM
Urizen's Avatar
Urizen Urizen is offline
There's some nice iron underneath all of that dust.
Old 07-15-2007, 09:11 PM
Holy Merde' ! Think you stumbled on to somethin' NEAT !!
Old 07-16-2007, 05:05 AM
cabinover's Avatar
cabinover cabinover is offline
Dazed and Confused
It's a keeper! Nice little mono setup in great shape.
Do I understand??...Ummm....Well....no
Old 10-22-2007, 03:08 PM
cruisaire's Avatar
cruisaire cruisaire is offline
PGA and Rainwater!
So, how's it sounding now? I need inspiration to get me going on mine.
Old 10-23-2007, 10:38 AM
Uh oh, now I'm embarrassed. It's still sitting there, untouched. Too many projects and not enough time.
Old 12-22-2007, 12:00 AM
shovel52
Guest
Posts: n/a
Wow small world, i picked up that same unit at a flea market last weekend. I started to part it out but told myself to wait. Mine is not in good condition.
A goldmine in tubes. Especially the seeing eye tubes are about $35 a piece. I havn't even checked the year yet. but It does seem to be well built! I removed the transformers, one to use on another project but I'm going to wait and just put this thing in the attic for now!
Old 12-23-2007, 09:54 PM
devoid's Avatar
devoid devoid is offline
NA Volvos and Amplifiers
I have parts here for that one. Contact me if interested.
What I don’t want is music that was written to be recorded.
Old 01-07-2008, 07:40 PM
truetone36's Avatar
electronics packrat
That Magnavox is from around 1947-48. They made that in several different cabinet styles. I've owned two of them over the years. That console should sound absolutely beautiful when restored.
Old 01-07-2008, 09:32 PM
Nolan Woodbury's Avatar
Nolan Woodbury Nolan Woodbury is offline
Shaken, not stirred
Pics are small...I can't tell what bands are on that set. If it's FM, would that feature the old band?
Neat set...but I seem to prefer the horizontal arrangement. Then again, I bet that big mono will sound good once tidy.
Bedroom: Marantz 2015 / Pioneer CS-88
Living Room: Zenith Y928 / MJ 1035 vintage stereos
Office: Zenith H845
Home desk: Zenith X338 / H272W Circle of Sound
Truck: Kraco Dust-O-Matic, circa 1977
Old 01-13-2008, 01:52 PM
I agree with the others who said your console will sound great once restored. I once had a Magnavox AM/FM tuner/amp chassis which I bought at a second-hand store near my former residence. Chassis only, no speaker or cabinet. I hooked it up to an old speaker I had laying around the workshop at the time (don't remember the workaround I did to bypass the field coil), put a length of wire on the FM antenna terminal and fired it up. Worked like a champ. Those old Magnavox sets were great, built to last--like Zeniths. This chassis was likely from a console like yours, with a record changer and even a position on the function switch, IIRC, for a TV (modern FM band as well), so my unit was probably part of a three-way entertainment center circa 1948-1950 when it was new.
BTW, my best guess is your set's tuner is set up for the pre-war 42-50 MHz FM band (which would date it pre-1948), though I could be wrong. I agree with Nolan; the pictures are too small, even when supersized, to show clearly the calibration markings on the dial scale. I do know the version of this chassis with the horizontal slide-rule dial tunes the modern 88-108 MHz FM band, however, so those chassis are postwar sets. If yours has the prewar FM band, it may be possible to find a converter that will take signals from 88-108 MHz range and downconvert them to a frequency in the old band, doing all station tuning at the converter, not unlike the UHF television converters of the '50s-'60s. Regency once marketed what it called an "FM Televerter" in the '50s that downconverted the modern FM band to a TV channel; this unit worked on the same principle as the converters I mentioned for downconversion of 88-108 MHz FM to the older prewar band.
Old 01-13-2008, 07:56 PM
Chad Hauris's Avatar
That's interesting that it actually has FM on the main tuner unit.
We have several of this type of set and they all were designed to use an optional FM tuner which is a completely self-contained unit with its own power supply which mounted in a pop-out panel above the main tuner unit. The main tuners on all of these we have is just AM and shortwave...none have had the optional FM tuner installed.
Chad Hauris
Old 01-13-2008, 08:08 PM
I had a chassis once that had self contained FM. I have also had a couple, like chad said, that had the seperate FM tuner chassis mounted above the main tuner. I'm thinking they had two tuning eyes. One was on the main chassis and the other was on the FM chassis.
