Old 08-31-2007, 08:21 PM
similost's Avatar
similost similost is offline
Rockin and Rollin....
To refinish, or not to refinish...
ok.. I know :, but the new to me 1941 Zenith 8s563 is in the car, and after I got done sanding down the bathroom walls, I was too tired to get it out tonight.. right now it's martini time...
Anyway.. I got this radio.. it's a little rougher than I was hoping.. The wood is all good, but the finish is pretty worn.
I know some of you saw the '39 7s363 I just recently picked up, and how great I got it looking, but it was in a lot better shape...
I'm not one who would typically want to remove an original finish, but in this case, I think the case would be a lot more appealing...
I've been watching e-bay auctions, and for some reason, most old consoles that have been refinished seem to sell for more than original finish ones that have been restored or are in great shape...
I really have no intention of selling this one, so value isn't so much a worry, but in the long run, what would you think would be a better option?
I will post pictures tomorrow, but until then, what are your feelings about refinishing?
I noticed on this '41, where there is what appears to be inlay, or a change of veneer, is actually a faux wood-grain finish over the under-laying wood, where as with the '39, it is actually a different type of veneer.. and not faux.. amazing the difference in how they were manufactured within two years.. .
Big ass speakers with too much power, and nowhere to go fast...
Altec A7-500; Peavey SUB118-HC
Modded Quicksilver 8417 Mono Amps; Tapco J1400
Behringer MX2004X; Tapco T-231; Peavey VSX; Pioneer SR-303
Technics SL-1200MKII; Pioneer RT-701; Yamaha CDX-1030; KLH Model 18
Old 08-31-2007, 08:53 PM
similost's Avatar
awww.. only one read? Normally asking for an opinion around here will get 10 replies in as many minutes..
Old 08-31-2007, 09:37 PM
radio63's Avatar
radio63 radio63 is offline
Still Y2K Compliant!
Originally Posted by similost View Post
I've been watching e-bay auctions, and for some reason, most old consoles that have been refinished seem to sell for more than original finish ones that have been restored or are in great shape....
Hi,
Well, your observation about Ebay is very interesting. I am a purist-type and unless the finish is an absolute hopeless disaster, I prefer to leave the original finish even if it is not up to par. Unless as I say the exisiting finish can't even be made to be presentable. I can live with some defects as long as it is original. I'm surprised that sets would seem to sell better refinished than with original finish, but then again there's no way to tell what people are going to buy.
You must do what ultimately pleases you in your collection. My only thing is that once an original finish is removed, there's no way to get it back again. To me refinishing is the absolute last resort if the exisiting finish can't be polished, oiled, rubbed, etc. Sometimes also spot refinishing may be in order if the cabinet on the whole is OK but just has some bad areas. It would be good to see pictures and then maybe that might generate more thoughts on this issue.
Gilbert
Old 08-31-2007, 09:50 PM
similost's Avatar
Thank you for your opinion.. I am the same way. I really am a purist, and hate to see ANY antique finish removed.
In this case, I'm not real sure what to do.. a lot of the areas of the faux finish have chipped off and the under-laying wood is showing. I'm sure I could probably spend a lot of time touching it up. I will post pictures in thos thread tomorrow. I'll also get a lot of close-up shots.. I know I could dissolve some of the finish and spread it around, but that isn't going to fis the faux areas..
I can live with crazing, and this has a lot. I know a lot of that is fixable with Howard's Restore-a-Finish, however, there is a lot of the Faux finish chipped off and missing.
On the top, there is maybe 4 or 5 rings? I thought about maybe just redoing that, but then that would look good, and the rest kinda weak.
Along the bottom of the base, it looks like there may have been some moisture, or water, and the finish is completely missing. It is bare wood...
I can deal with some scrapes, missing finish, etc, but over all, I would give this case a 4 as far as finish.. some might give it a 6.. .but I would much rather buy an 8 or 9.. but I didn't.. the chassis and the wavemagnite were easy 9's... just need to fix the rubber and cloth rot on the wires.. which is easy compaired to the finish... the grill cloth is a 10...
I really am scratching my head as what to do in this case...
Old 08-31-2007, 11:26 PM
Adam's Avatar
Adam Adam is offline
I just had the same dilemma myself with that RCA 721TS, that finish wasn't really bad but it wasn't great, it had scratches, some vineer missing on the bottom, finish off in a few places, but it was the original finish and it wasn't that bad, in the end I sanded it a bit with some 600 sandpaper, went over a few spots with some stain on a rag and then sprayed over the whole thing with clear laquer in a can. It looks good from across the room, but you can see all the problems with it close up. I have it sitting next to my Hoffman 610 which was originally really bad and I totally refinished (someone even had carved their name in it), but now the Hoffman looks better than the RCA, and I'm still debating whether I should have completely refinished the RCA.
Old 08-31-2007, 11:29 PM
similost's Avatar
So you're still not satisfied... hhhmmm
Old 09-01-2007, 12:57 AM
Adam's Avatar
But then I think if I went the other way and refinished it I would probably be saying just the opposite, that it wasn't that bad and I should have kept the original finish.
Old 09-01-2007, 01:19 AM
similost's Avatar
This is the inner fight I keep struggling against...
I'll post pictures tomorrow, and then I'll go with what everyone thinks is best... This cab is right there in the middle of what to do...
Old 09-01-2007, 04:12 PM
similost's Avatar
OK.. maybe this will get people to help me decide if I should refinish this...
Old 09-01-2007, 04:18 PM
similost's Avatar
Here's a couple of the fidgety bits..
Old 09-01-2007, 05:24 PM
similost's Avatar
come on.. no one has any opinions as to whether they would refinish this one or not?
Old 09-01-2007, 06:27 PM
similost's Avatar
Still looking for opinions.. no right or wrong answers.. just trying to decide which way I wanna go...
Old 09-01-2007, 06:33 PM
marantzfan's Avatar
marantzfan marantzfan is offline
AK Subscriber
Go for it! If nothing else, thats a cool looking decoration for your living room!
Main System:
Sunfire Classic Tube Preamp, Sunfire 300 Amplifier, Cambridge DAC Magic, Carver Amazing Silvers
Secondary System:
Sansui AU-X901, Technics SL-1210M5G w/ Benz Micro Silver, Vandersteen Model 3s
Old 09-01-2007, 06:40 PM
similost's Avatar
It actually works.. but I'm gonna recap it..
Thanks for the vote.. it's kinda the way I'm leaning.. the one behind it is in my wife's "antique room" den, and has a really great finish on it.. this one would never look that good, so that's why I'm debating.. will probably put it into our guest bedroom..
Old 09-01-2007, 08:27 PM
Dave A's Avatar
Dave A Dave A is offline
Whoa Nellie! It looks like it has some version of photofinish or paper-grain trim on some of the smaller width crosspieces. Both are basically wood grain decals applied over veneer. Specifically the four surrounding the dial assembly and all of the speaker crosspieces and side trim.
You can see in the photos where it has already lost some of this fake grain finish and is down to the veneer underneath. Restoring this is way above my skill level, but some web searches can give you some info if not help.
Any refinishing will evaporate them and leave you with the underlying veneer or hardwood which will not re-grain like you see right now.
Dave A
