Old 09-18-2007, 02:40 AM
Film to TV Projector?
I presume this is what they used to show films on TV back in the day?
http://cgi.ebay.com/RCA-275-VINTAGE-...QQcmdZViewItem
Old 09-18-2007, 12:24 PM
kx250rider's Avatar
REAL TVs have TUBES!
Definitely some sort of film chain... RCA made a lot of them in order to show filmed TV shows (Lucy, et al), in the pre-videotape days. I hope someone else will ring in on this.
Charles
Old 09-18-2007, 04:27 PM
polaraman's Avatar
<--1956 300B
That has to be one heave ^&TCH!
polaraman
On the Bench: Master's Degree Thesis!
Old 09-18-2007, 10:46 PM
matt_s78mn's Avatar
matt_s78mn matt_s78mn is offline
That is the projection half of a Telecine. Generally those RCA Telecines consisted of a projector like that one, and a camera that pointed into the lens of the projector, and the two units sat side by side. Modern telecine units are contained all in one unit instead of two separate pieces. Back in the days before videotape or "television tape" recording was a common practice, equipment existed that recorded the video images onto film. This was called a kineoscope recording. Basically this consisted of a 16mm film camera that was focused on a video monitor and recorded the tv image and sound onto the film. Therefore tv stations had these telecine units to playback previously recorded content, such as syndicated programming, news pieces, commercials, etc. to air via the telecine machines.
Old 09-18-2007, 11:19 PM
The station I worked for for some reason called it a Film Chain or Film Island. One island had two 16mm projectors and a slide unit. The other Island had one 35mm one 16mm and a slide unit. All RCA equipment. They used them live on the air untill the late 90's.
Old 09-19-2007, 04:57 PM
"chain" because it included everything needed from end to end to turn film into TV signals; "island" because it stood in the middle of the floor so you could get at all the pieces.
Besides kinescope recordings, it was used to broadcast locally made news films before the days of camcorders, and also possibly 16 mm prints of syndicated TV shows and old movies. Some facilities could do 35 mm (I think mostly networks). If it was built to handle the real old nitrate prints, it wouldn't be an island, but would have a separate fireproof projection room.
Old 09-19-2007, 09:22 PM
fujifrontier's Avatar
fujifrontier fujifrontier is offline
roundie not so n00b
*sniffle* oh the good old days
Originally Posted by TVTeufel
Another idea.....instead of expensive anti-psychotic drugs, let's provide schizophrenics with dummy bluetooth headsets. They'll easily blend into the crowd, although I suspect their "conversations" would be far more rational than those of the typical Wal-Mart shopper.
Ron
Old 09-19-2007, 09:30 PM
I still remember changing a hot blown projecter bulb during the "Brady Bunch" those were the days... We did get some film on 35mm mostly spots at that time they would be played once and recorded on the ACR25 2" qaud spot recorder now that thing was a work of art. I would really like to see one of those running again. Now it's all boring servers.
