Old 10-01-2007, 12:04 AM
jimbofish's Avatar
jimbofish jimbofish is offline
Sourse... of coarse!
Silvertone loop antenna damaged
When I moved my mother's Silvertone console radio, the built-in loop antenna got tangled in the dolly and most of the wires broke. Without it, the reception now is non-existant. I'm wondering if anyone is familiar with these and can tell me how to rewire it. There are too many loose ends to know which one connects to which.
Basically, it was two loops of two wires each that wound around the interior of the cabinet. One loop went around the cabinet from the right front top corner, down the right front side to the bottom right front corner, then diagonally across the bottom to the left rear bottom corner, then up the left rear side to the top left rear corner, then across the top to the top right front corner. The second loop was diagonally opposite to that one. The antenna connects to the chassis with a 5 wire plug. The wires crossing the bottom of the cabinet are what was damaged.
I'm hoping someone is familiar with these or can tell me where to find a diagram to rewire it.
