Old 10-20-2007, 08:27 AM
OMI's Avatar
OMI OMI is offline
Montgomery Ward Radio from 1936 for $50.00
I know this should go in the deals secton, BUT thinking it will be seen here first by thoes that are most interested... 1 1/2 hr to go on shopgoodwill.com with no bid.. (starting at $50.00)
http://www.shopgoodwill.com/viewitem.asp?itemID=3087427
I may be a fool but I did put in the min. bid and was the only person bidding ... Soooo for $50.00 and $14.00 shipping it is now mine....
MiMi Bobeck Body Double... Think I can get a GUEST shot on the Drew Carry Show
Old 10-20-2007, 01:57 PM
Tom Bavis's Avatar
Audiophool
Picture is gone, but I looked up 62-229 elsewhere - if complete, I'd pay $50 any day.... nice dial!
Old 10-20-2007, 03:16 PM
OMI's Avatar
OMI OMI is offline
Looks clean in the pics. It is a Table-Cathedral-Radio. Does look like the speaker may be missing, but from the pic it looks like the rest of "guts" are still intact. The cabnet and dial look in great shape. Once I get it I will post some pics. The only info I found was here:
http://www.radiomuseum.org/r/montgomery_62_229.html
Old 10-20-2007, 09:44 PM
Tom Bavis's Avatar
Audiophool
Schematic is at http://www.nostalgiaair.org/PagesByM...0/M0011360.pdf
WARNING! This is a 32V farm radio! Do NOT plug it in! It was made to run on batteries (32V with a windmill to charge them) before AC was wired in the rural areas. If it WS plugged in, expect some blown tube heaterss. No big deal - all are common numbers, I have 'em.
Old 10-20-2007, 10:04 PM
OMI's Avatar
OMI OMI is offline
Thanks….
That may be why the write up says:
“This is a Montgomery Ward Radio from 1936. It is a model 62-229. There is no back panel, so the inner workings are visible. There are two wires which are connected on one end, but not on the other. We have no way of testing whether or not it works. The front is in good condition with only a few scratches, and it has a floral print fabric covering the speaker grill. The radio is 14.5” by 17” and 10” deep.
Hmmmm I may have snagged a rather unusual radio… One of the pics was of the data sheet still glued in the cabinet and it did clearly state 6 tube 32V D.C., 40 Watts in big letters…
Does this mean that I need to get a windmill to go with the radio now
Old 10-20-2007, 10:10 PM
blue_lateral's Avatar
Yes. Thats exactly what it means.
You will need to scare up or build a 32v DC power supply. Look around in the archives on the antiqueradios.com forums. It isn't that hard to build.
Congratulations, thats a cool looking set!
Old 10-21-2007, 12:50 AM
I thought that radio looked a bit familiar. I have a small AM/FM replica cathedral radio that looks something like the MW, except for the grille cloth and the shape of the cabinet (the MW set looks like a tombstone; my little set is a replica of a 1934 cathedral).
Tom Bavis's warning against indiscriminately plugging the MW radio into a 117-volt AC wall socket should be heeded, as he is correct. This type of radio is not designed to be powered directly from the AC line; if such is attempted, it will likely burn out not only a tube filament or two, but the rest of the radio will almost certainly be severely damaged if not destroyed as well. These radios, as Tom mentioned, were originally designed to be powered from windmill chargers such as the Zenith Wincharger, but could be operated in a pinch (I would think, anyway) from five six-volt car batteries connected in series (for 30 volts). They could also be powered, as was mentioned, by an external 32-volt supply. Personally, I'd go the external PS route, since using five 6-volt storage batteries is messy and unsightly, not necessarily in that order. Such a lashup is fine for testing, but I wouldn't want this radio in my living room with five car batteries underneath, unless I could somehow hide the batteries--and then there's the acid problem. I wouldn't want to have to worry about electrolyte spilling out of one or more batteries and burning a hole in the carpet, or worse. I wonder how people handled these problems (acid spillage and the looks of the battery) with farm-battery radios that used a single 6-volt tractor battery.
Old 10-29-2007, 06:10 PM
OMI's Avatar
OMI OMI is offline
Received the radio today. The cab is in great shape. Someone had started to work on it and had replaced the grill cloth. They had removed the speaker also It also looks like the radio had a base??? Had one more pic to UL. but that function is acting up
Old 10-29-2007, 07:21 PM
Uhh, you still did quite well... The flowerdy print speaker fabric would HAVE to go, though...
Old 10-29-2007, 07:29 PM
jonman jonman is offline
Looks good OMI! You could probably get away with some strips of molding stained to match the rest of the radio. It would look good to replace the flowered speaker fabric with some burlap or something similar. You mad a great find.
Old 10-29-2007, 08:32 PM
OMI's Avatar
OMI OMI is offline
other pic. Had to save as a gif???? to get it to UL...
One more "PROJECT"... Have it hiding at the office for now Will have to see if I can find a period speaker later... Looks like some minor repair to the cab in a few places... When I get to that point I will be seeking help from the experts here that can point me in the right direction and help me do it right
Old 11-12-2007, 11:04 AM
OMI's Avatar
OMI OMI is offline
Got a Montgomery Ward's 1936 catalog from E-Bay. Here is the add for this radio...
Old 11-12-2007, 01:05 PM
It looked like there would be more of a base mounted on the bottom. I got a better idea seeing the original catalog picture. Thanks for sharing.
Old 11-12-2007, 02:51 PM
OMI's Avatar
OMI OMI is offline
That is what I thought, but it looks like it was made that way. The picture in the catalog is a lot clearer and that was the way it was designed and built.
