Old 12-09-2007, 04:32 PM
radio nut's Avatar
Born in the wrong decade
Unhappy osc coil
While I am trying to get info on my first tv I decided to try another only to find that it has a bad osc coil.It is corroded and beyond repair. Is it possible to get another? it is a crosley S11-459MU (sams set153 folder 3 date 12-51) Thanks, Doug
Old 12-09-2007, 05:11 PM
Hi Doug, are you talking about the horiz coil?
Moyers might have one if you can get a part number from the Sams, maybe it's generic enough that one from another set might work also?
Old 12-09-2007, 06:21 PM
radio nut's Avatar
Thank you, It is the horizontal osc. Well, I tried a search for moyers on my computer and all it pulls up is stories about Bill moyers, Do you have a phone # or what did I do wrong on my search?
Last edited by radio nut; 12-09-2007 at 06:26 PM. Reason: needed to add a question
Old 12-09-2007, 07:21 PM
mattdavala's Avatar
mattdavala mattdavala is offline
Here is the link. Hope they have your coil.
http://www.moyerelectronics.com/
Matt D
Old 12-09-2007, 09:31 PM
radio nut's Avatar
Thank you, I did find moyers site and put in a request for my part. Keep in mind I am new to television, It is the sweep transformer I need.I stated what I needed before I looked at the diagram. It looks like a big coil and that is why I thought it was a coil. It does not look like any transformer I have seen.
Old 12-09-2007, 10:27 PM
Sounds like you're talking about the flyback transformer?
Does it look sort of like like a donut?
Old 12-10-2007, 10:06 AM
radio nut's Avatar
transformer
Well, I guess it does look like a donut. It has about 9 taps and a couple different sections. I called it a sweep Trans. because that is what the diagram has it listed as.
Old 12-11-2007, 02:10 AM
Tubejunke's Avatar
Its a flyback.
Old 12-11-2007, 11:14 AM
radio nut's Avatar
flyback
Moyers does have the flyback I need. Thank you for pointing me in the right direction.Doug
