Old 02-09-2008, 07:08 PM
cdmarion's Avatar
cdmarion cdmarion is offline
Smoking Resistor Please Help
I just re-capped a Bendix model 526A chassis R1 (5 tube AC/DC) and now i have a smoking resistor. I've tried half the day to figure this out and am coming up with nothing..........so it's time to ask. Please forgive my ignorance, this is my second recap.
Before i started, the radio powered up had a loud hum and would tune in stations, although the sound was distorted.
All values of the new caps are correct, I’ve double and triple checked. The only exception is one of the electrolytics was originally a 12mfd @ 150V and i replaced it with a 16mfd @ 450V. I'm under the impression that one can substitute an mfd value as much as +100% and any voltage would work as long as it was the same or greater than the original. All caps should be in their correct places, I remove one cap at a time and replace it, so as not to get confused and mix things up. Could the electrolytic be the problem?
Now when i turn on the radio there is a hum in the speaker that is constant and does not change with volume and the 150ohm 1W R8 resistor is smoking. It looked like it had been hot before i started but did not smoke before i i re-caped. I've never seen a resistor like this one before it kinda looks like a paper cap, except it's white in color and has four color value marks painted on it. It tests 159ohm with the meter so i'm assuming it's still good. I plan on replacing it as soon a i can find one.
The 50L6GT power output tube tested bad and was replaced with a good tube before i powered it up. I'm assuming this was the cause of the distorted sound? I'm not sure yet.
I've made sure that no leads are touching and shorted and the tubes are in the correct sockets.
I've attached the Riders schematic, i'd appreciate any suggestions on where to start looking.
Thanks-Chris
Old 02-09-2008, 07:16 PM
cdmarion's Avatar
I forgot to mention, When i used the dim bulb tester with a 15W bulb it did not smoke, when i stepped up to the 40W it smoked, i'm not sure if that means anything?
Old 02-09-2008, 07:47 PM
Chad Hauris's Avatar
R8 appears to be the cathode resistor for the 50L6...so the overload has to be in that circuit. Try removing the cap which goes from cathode to plate...also check for maybe a carbon track on the 50L6 socket.
Chad Hauris
Old 02-09-2008, 08:38 PM
cdmarion's Avatar
Ok, just removed C11 and C10 and R8 still smoked. I don't see anything that looks like carbon tracks to me on 50LG.
Old 02-10-2008, 07:02 AM
Electronics Accumulator
Try pulling the 50L6 out. That will kill your filament current (breaks the string) and your B+ (no rectifier filament, no output). See what happens. If the resistor still smokes, then there is a short somewhere. Go over it with a clear mind and a bright light - look for dripped solder, bent tube socket pins touching, capacitor leads touching something, etc. It's easy to bend things just close enough to touch while you're working. We have all been there, and done that. Don't worry - you'll find it.
And the resistor didn't smoke with the 15W bulb because the 15W bulb has a much higher resistance than a 40W bulb. It couldn't get enough power to smoke.
Can you post a photo of the underside of the chassis?
-Ian
Old 02-10-2008, 10:20 AM
cdmarion's Avatar
Originally Posted by RetroHacker View Post
Try pulling the 50L6 out. That will kill your filament current (breaks the string) and your B+ (no rectifier filament, no output). See what happens. If the resistor still smokes, then there is a short somewhere. -Ian
I pulled the 50l6 with no change, so i went looking for the short again. This time i found it,a pair of leads touching- when looked at from one angle it looked fine but from another angle it was touching. fresh eyes made the difference. I had looked at this thing so long yesterday that my eyes were crossing. Now the radio works great.
Another word of caution (to the new guy or gal that reads this), I knew it was time to stop last night when after putting both hands in the chassis i realized that i had not unplugged the radio, just turned it off at the volume knob. I didn't get shocked but i was getting tired and careless. I figured i dodged a bullet there. I probably should have stopped a couple of hours before i realized i needed to stop. Lesson learned.
I appreciate you guys helping me out.
Here's a pic of the two (now functional) radios i have under my belt so far. Time to start another. (1947 Bendix Model 697A step table radio with phantom dial)
Old 02-10-2008, 10:37 PM
Good going! Don't worry - it's easy to make these simple little mistakes, especially when you're tired. No matter how much experience you have, every now and again you'll do something like this. Case in point, a few weeks ago, I recapped a simple Airline console radio/phono. I did a full recap and replaced the selenium rectifiers with diodes. Plugging it into the dim bulb tester after this read a direct short, and a power resistor inside was starting to smoke. I went over the wiring time and again, checked and rechecked the electrolytics and diodes. Everything looked good. Start pulling tubes and testing - still no go. I didn't have a schematic, so I was just going by the components in the set. Eventually find out that I had installed both diodes backwards. I had gone by the markings on the old selenium rectifiers, and not by the circuit itself. You see, the + on a selenium stack is really the _cathode_. Not the anode as I had thought with a tired mind. Silly me.
Being patient, rechecking, coming back with a clear head, and using proper test gear - like the dim bulb tester - are all great ways to solve problems. And it's very satisfying when you find it too!
-Ian
Old 02-17-2008, 08:19 AM
Old1625's Avatar
Old1625 Old1625 is offline
Amen to the caution about working on gear when tired or perhaps otherwise impaired. Best to go at things with a fresh, alert mind, and with care.
A long time ago a friend of mine sustained serious injury when he brushed a couple of terminals in the power supply of a mighty tube amp he had just built. He was tweaking the bias and balance controls underchassis when his pinkie finger on his right hand went some place in the chassis where no pinkie should go. He burned two craters clean to the bone in that finger, and his whole arm turned black-and-blue, and was numb and paralyzed for several minutes. He said he felt like he was trampled in a stampede, and his arm tingled and buzzed for several hours after the incident. He was tempted to get himself to hospital, but wasn't sure he could drive safely, and nobody else was home at the time.
The power transformer was a mil-spec type with a series of windings wired up and rectified to produce a 900V potential at 1 ampere. It was the terminals of the 1000mf main filter he brushed.
He laid out the following rules after that:
1) No working on such gear when impaired by fatigue or imbibement.
2) Try to have an assistant on hand (usually me) if undertaking a hazardous task with powerful equipment.
3) Always be sure that one can get help if things go bad.
4) Never place both hands in the chassis unless the power is down and the 'lytics are double and triple-checked for charge.
My good friend is still around to tell the tale, because his left hand happened not to be on the bench at the time, and the lion's share of the current went through 2 inches of finger. If it had gone through his torso from hand to hand God only knows....
Old 02-24-2008, 08:23 PM
ellconi's Avatar
ellconi ellconi is offline
Hi All, I would like to thank Retrohacker and Old 1625 for the encouragement and tales; I also did the same polarity reversal on selenium rectifiers. I am grateful for not ever getting a severe electric shock while working on radio equipment. I attribute this to being very careful and always using isolation transformers. The first page of the electronics school manual explained how few milleamps are required to kill you! I'm glad it stuck. Curt
Old 03-03-2008, 03:36 PM
majoco's Avatar
majoco majoco is offline
ZL2MC
Hi Guys - perhaps we need another column - "Stuff-ups I have made"! Some are pretty frightening. Many years ago I had to retune a 400watt AM beacon transmitter to a new frequency. The antenna was connected inside the shed with 1/4" copper tube which was earthed by a grounded clip when servicing. Couldn't get this Tx to tune properly, lots of output current but no power. Then my mate says "you haven't taken the ground clip off" so he hops up on a stool and takes the clip off the copper. Now the Tx put out some power! Drew quite a good spark about 2feet long before my mate dropped the clip. We sat outside for a while and had a smoke before checking on the damage - fortunately none!
Regards - Marty
