Old 02-20-2008, 12:49 AM
jayzjayz jayzjayz is offline
55" MAGNAVOX R-Pro template for correct Convergence Geometry
Magnavox R -Pro 55" inch screen If anyone knows where I can find a clear Geometric template, for my set please let me know. I recently changed the fluid in the 3 CRT's. The picture looks great. However, when I use the code to align my set I can see that the Green grid is not perfect, due to the fact that I had taken out the guns to clean and refill. I know I am close to being on target but I would like it to be better if at all possible.
I would be grateful for any help. Actually my friend was going to throw the set out ,because everything was green. But he asked me if
I wanted it and I said yes. I never worked on any TV before, but I did some research and found out how to change the coolant.
I love it now. So I am trying to get as close to perfect as I can.
I would be grateful for any help. Model # 6P5440 W103
Even if some one could send me a photo of what the Green convergence pattern looks like that would help me allot The template number is - 55" inch ST4170 I need to know what the original Green pattern looks like
Thanking you in advance
Jay
Old 02-20-2008, 09:43 AM
fujifrontier's Avatar
fujifrontier fujifrontier is offline
roundie not so n00b
Hey! Do you have pics on how you did it? I just let the glycol drain out of the fill hole; did you actually remove the lens and wipe the tube face? I was too afraid to do this....
Originally Posted by TVTeufel
Another idea.....instead of expensive anti-psychotic drugs, let's provide schizophrenics with dummy bluetooth headsets. They'll easily blend into the crowd, although I suspect their "conversations" would be far more rational than those of the typical Wal-Mart shopper.
Ron
