Old 07-05-2008, 03:14 PM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
Leningrad T1 - rare Sovjet tv set from 1946
Hello,
a very rare Sovjet tv set, the Leningrad T1, can be seen on
http://www.molotok.ru/item394311376_...1946_goda.html
Only three surviving sets of the T1 are known. This web page is worth a look for its excellent photos.
Kind regards,
Eckhard
Old 07-05-2008, 03:25 PM
oldeurope oldeurope is offline
Hi Eckhard,
thanks for the link.
Old 07-05-2008, 05:43 PM
Wow...Wonder if it still works, or could be made to work...Muchas Gracias for the link, Eckhard...
Old 07-05-2008, 06:50 PM
Smile
Warning! Silly cold war era remark follows:
Is it a color TV, but with only red and no green or blue? So the viewer would only see the red (communist) viewpoint?
Old 07-05-2008, 07:06 PM
Arkay's Avatar
Arkay Arkay is offline
Things are no longer red there, since the fall of the Soviet Union. Because the set was never made to handle green or blue, THAT's why there is no picture at all on the screen... nor red, no green, no blue = no pic, right?
Old 07-05-2008, 07:26 PM
CarlV's Avatar
CarlV CarlV is offline
Saved some pics to our site just in case.
Carl
Old 07-05-2008, 09:18 PM
electroking's Avatar
a- v- karma member
I especially like the word above the antenna terminals, literally F-EE-D-E-R.
Old 07-06-2008, 07:27 AM
Old1625's Avatar
Old1625 Old1625 is offline
No matter what, that is one sweet-looking find! Very clean, and looks as if it could easily be made to play--assuming the kine is OK. I wonder what standard they used over there at the time, and how much it would take to tinker it to operate as NTSC....
(Edit: A source offers that it operated on the French SECAM standard.)
Old 07-06-2008, 08:05 AM
mr_fixer's Avatar
mr_fixer mr_fixer is offline
It looks very American on the inside, all octal tubes. I wonder if it is a partial copy of a US prewar set?
Old 07-06-2008, 08:21 AM
yagosaga's Avatar
VK Member
Yes, there is a lot of American technology in it. It is based on American tv sets which were exported during WWII. The original television standard is the RCA 343 line standard with 25 frames, which was changed to 625 lines in March 1946. IMHO the picture tube is a 7" round crt 18ЛK15.
Kind regards,
Eckhard
Old 07-06-2008, 11:12 AM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
"....1946! How's that fit in with your post-war Commie Conspirascy?"
Gen. Jack D. Ripper
Old 07-07-2008, 02:16 AM
yagosaga's Avatar
VK Member
Originally Posted by M3-SRT8 View Post
"....1946! How's that fit in with your post-war Commie Conspirascy?" Gen. Jack D. Ripper
Look at the photos: most of the resistors are German. Rosenthaler and Siemens parts. And the micas are British. The picture tube is a replacement. The original crt had no ion trap.
This is true conspiracy...
Old 07-07-2008, 02:53 AM
The chassis looks extraordinarily clean, and look at the size of that power transformer! what Hz did the Russians use then/now?
Old 07-07-2008, 05:14 AM
yagosaga's Avatar
VK Member
The Sovjets used 220 Volts, 50 Hz. Due to the lack of suitable television valves, they used different filaments voltages. That's the reason for the large mains transformer. The horizontal frequency is 8,575 Hz. Video bandwidth is appr. 1 to 1.5 MHz.
EHT is generated in the line output circuit, but there is no damper.
- Eckhard
Old 07-07-2008, 02:04 PM
a- v- karma member
SECAM is too recent
Just a note that SECAM was a color transmission standard developed
from the late fifties, thus it is not relevant to this 1946 receiver. Of
course the matter of compatibility of early Soviet TV sets with
other European systems remains open.
