Old 07-11-2008, 12:33 PM
seventhz777z seventhz777z is offline
European AM Aerial/Earth Connectors for Radio Tuners?
Does anyone happen to have or know where I might be able to aquire three AM Aerial/Earth Connectors found on old European Radio Turners? They split open to allow you to connect the radio wires to the pins. The pins themselves come in two different versions.
here is a pic of it when 'open'
Old 07-12-2008, 12:11 AM
gadget73's Avatar
gadget73 gadget73 is offline
You can use banana jacks for that. They're not two wide like the Euro jobs though.
Random bits of stuff in the collection:
Yamaha YP-D4 turntable with B&O MMC 10E cart
Allied 495 receiver
2 Magnavox amps, AMP150 and an AMP178, currently under the knife.
Onkyo TX-4500
Onkyo Radian III speakers
Old 07-14-2008, 11:46 AM
thanks for the tip, but I am hopping to stay original to restore than to modify.
Old 07-24-2008, 06:14 PM
larschr's Avatar
larschr larschr is offline
TeeVee collector
One solution is to solder metal pins with the right thickness to the wires and just push them into the holes. If nothing else, it´s a good temporery solution until you find the proper connectors. They are just about impossible to get even in europe, and the similar looking VHF and UHF TV connectors isn´t even worth asking about.
Old 08-25-2008, 01:13 PM
I appreciate the tip. I'll try that.
