Old 07-23-2008, 08:24 PM
Hemingray's Avatar
Hemingray Hemingray is offline
Vintage Geek
neat little Motorola AM/Fm tube
Scored this rather cute little Motorola tabletop for $15 today while on the road. Sporting 7 tubes, and a Selenium rectifier, she actually sounds good on original parts (not even any hum!). Interesting to note on this is the sticker on the back from a repair shop,t he tube in the tuner being labeled as "HCC85" (I'm guessing a european version of the 17EW8?(not pictured)), and the three wire cord (third wire is supposedly the "internal antenna")
The only real problem that's plauging it, is the FM tuning is way off (local station 98.3 is coming in around 95, no tuning below 89 at all)
Death: Man how old is this TV?, You probably get the DuMont network on this thing!
Old 07-23-2008, 08:50 PM
I think you can replace the selenium rect. w/a diode-those old seleniums will let go like a cap will, but they will STINK up yr house, & yr neighbor's house...I might think hard about re-capping it, too...THEY'RE prolly not TOO long for this world, either...
Old 07-23-2008, 09:05 PM
Hemingray's Avatar
Vintage Geek
I intend to do that here in awhile, (I don't want any odd stinks in here anyways, and I am aware of the bad smell of a blown selenium rectifier). It does have the original filter, but shall be replaced for reliability sakes, along with the rectifier. Best part of this is the parts are all board mounted, easy to replace.
Any idea what may be throwing the FM tuning way off like it is?
Old 07-23-2008, 09:11 PM
Celt's Avatar
Celt Celt is offline
Peanut Head
Front end alignment needs to be tweaked a bit I'd say.
Old 07-23-2008, 10:04 PM
Randy Bassham's Avatar
I have an FM only Motorola set in the same cabinet.
KAØSCR
Old 07-24-2008, 12:06 AM
gadget73's Avatar
gadget73 gadget73 is offline
Normally I'd say its out of alignment, but its vaguely possible (this is a long stretch) that the B+ voltage is low due to the selenium rectifier beginning to fail, which is causing the oscillator to drop out down low. More than likely its an alignment problem but I'd check the B+ just for yucks. I had problems like that with my import sets. When set to 127v on a 125v line voltage, the FM band would drop out below about 95 mhz. I set it to 115v, and it brought the B+ up to spec. No more FM band problems.
Random bits of stuff in the collection:
Yamaha YP-D4 turntable with B&O MMC 10E cart
Allied 495 receiver
2 Magnavox amps, AMP150 and an AMP178, currently under the knife.
Onkyo TX-4500
Onkyo Radian III speakers
Old 07-24-2008, 08:27 AM
jeffsod jeffsod is offline
I too have the B1W FM only version of this nice little radio. I loved the style of it and couldn't resist it. I picked mine on that auction site last summer and its in mint condition. Mine was well taken care of and worked quite well.
In my office I couldn't pick up too many stations so I tried a new HCC85 to see if that would help and alls that did was throw off the alignment which had been very good until that point. Doh!
I haven't done any updates on mine yet but hope to get them done at some point. I suppose this is one radio I might be able to tackle on my own. Getting to its another matter.
Heres what the FM only looks like-
Old 07-24-2008, 09:20 AM
Celt's Avatar
Peanut Head
Dang. I like that!
Old 07-24-2008, 05:34 PM
OvenMaster's Avatar
DTV blows
I thought I'd seen that style of dial before! Voila: 1966 Plymouth Fury dashboard!
Tom
Old 07-24-2008, 09:24 PM
Hemingray's Avatar
Vintage Geek
You suppose Motorola got their design idea from Plymouth?
Old 07-26-2008, 10:42 PM
Hemingray's Avatar
Vintage Geek
Well, set down to work on it tonight, Replaced the three section electrolytic filter and the selenium rectifier, as well as a defective 12BA6 (severe grid leakage) in the FM IF amp. Seems now that it's slightly further off. Anything else I need to look for?
Old 07-28-2008, 12:19 AM
A '66 Plymouth Fury was what I was driving when we were married in 1971. Huge car with big V-8 and still got 19-21 MPG on the highway at 75-80 mph, what a cruiser.
KAØSCR
Old 07-28-2008, 07:57 AM
folks had one when I was growing up. What a tank.
Old 07-28-2008, 05:16 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Do not attempt to adjust your set.
Old 07-29-2008, 02:33 PM
gadget73's Avatar
Probably going to have to align it. It could also have a bad small value cap in the oscillator section, maybe across or in series with the coil thats throwing things off. If its only a few mhz off, you may be able to adjust around it but it is possible for mica caps to fail. Either that, or someone has had the golden screwdriver in there and twiddled with the wrong adjustment sometime in the past.
Allied 495 receiver
Onkyo TX-4500
