Old 04-26-2004, 07:03 PM
Dave A's Avatar
Dave A Dave A is offline
ETF Convention photos
I will follow this with another dozen photos from the convention trying to highlight the best of the best and a short description of each photo. I am putting this in the color section because the theme seemed to be the CBS and mechanical color. All other specialties are here also.
This could take a bit at dial-up, so have patience.
And now, the photos!
First is the RCA TRK row from the museum collection.
Dave A
Old 04-26-2004, 07:07 PM
Dave A's Avatar
This is a group photo of all of the owners of RCA Model 5 (Rose Bowl) color sets. Ed Reitan, noted RCA color broadcasting expert, is in the middle with the dark shirt. He gave a splendid introduction to the push behind the CBS mechanical color system.
Old 04-26-2004, 07:11 PM
Dave A's Avatar
Dave Johnson explains the Western Television "Visionette" mechanical set. He had a mechanical reproduction camera (behind the display) operating on a turntable model (a' la Felix) to put an image on the screen.
Old 04-26-2004, 07:23 PM
Dave A's Avatar
Darryl Hock shows the unnumbered 1938 GE prototype set. Note the 7 pushbuttons for channels. One more than later production models. You can also see the diagonal cut on the back of the chassis pan that is unexplainable considering the cabinet. It also had several RCA television experimenter parts. The yoke was clearly the same as a TRK from the era.
Old 04-26-2004, 07:25 PM
Dave A's Avatar
Steve McVoy describes the GE "Octagon" mechanical reproducer atop it's receiver.
Old 04-26-2004, 07:28 PM
Dave A's Avatar
Darryl Hock is back with his display of RCA TT-5 dealer advertising showcards and hangtags.
Old 04-26-2004, 07:31 PM
Dave A's Avatar
Chuck Pharis, noted broadcast equipment collector, shows off what is believed to be the original pencil and watercolor artwork for the RCA "Indianhead". This was rescued from the top of a dumpster full of RCA documentation. Pure luck that this was found. Chuck also had the followup artwork for the full test pattern. Check his website in the following weeks for posting of these documents.
Old 04-26-2004, 07:40 PM
Dave A's Avatar
Chuck Azalina stands with his Philco 15" color engineering prototype. You may have seen his previous postings on the travails of restoring this set. It stayed behind at the museum for display. This set was based on a previous Philco B&W set and modified for color. Chuck had no references for the circuit and had to draw the circuit on his computer by tracing every wire and component. It appears to be an all Philco design with no RCA circuits involved. The CRT is a Sylvania badged prototype and is in good condition.
Old 04-26-2004, 07:47 PM
Dave A's Avatar
Darryl Hock stands in front of the display of the three variants of mechanical color sets. The grey beast is the Grey Research studio color monitor that Steve McVoy has restored, next is the CBS color set from John Folsom, and farthest right is the aftermarket Col-R-Tel color converter from Dave Johnson.
Darryl is holding the "NTSC to whatever" converter he and others have developed to generate pictures on sets with obsolete formats. The range goes from the earliest mechanical standards to the oddest color.
It is a prototype at the moment.
Old 04-26-2004, 07:52 PM
Dave A's Avatar
A screen shot from the Col-R-Tel color converter. It is running on a B&W monitor Dave has adapted for use with the wheel and is fed from a DVD.
Old 04-26-2004, 07:56 PM
Dave A's Avatar
Another screen shot from the Grey Research monitor. The distortion at the top and bottom is from a temporary magnifier lens. The blueish tint is correctable via the scan converter depending on the set it is used on. This unit was set for the CBS set for the demo as they were all on the same video feed.
Old 04-26-2004, 08:00 PM
Dave A's Avatar
John Folsom standing in front of his CBS set. You can use the set as a purely B&W set by hand clearing the color filters out of the way, or switch it to CBS color. This set is reported to have come from the home of William Paley.
Old 04-26-2004, 08:09 PM
Dave A's Avatar
Color bars on the CBS set. It was amazing how flicker-free to the eye the Grey and CBS sets were. The Col-R-Tel was noticeable but not objectionable considering the conversion process they used.
This is the end of the photos. Post replies as you wish.
Dave A
Old 04-26-2004, 10:17 PM
Cory's Avatar
Cory Cory is offline
Cory Heisterkamp
Unbelievable! I guess I know where I'll be next year
How often do they fire up the sets they have on hand? I'm contemplating heading that way later in May just to see the collection (something I've been wanting to do for a long time) and would love to see at least one piece of impressionable equipment doing its thing.
Cory
Old 04-26-2004, 11:44 PM
heathkit tv
Guest
Posts: n/a
That Indian head that Chuck is holding reminded me of an idea that I've had brewing for a while now.......seeing as I'm into Indian motorcycles, a copy of this for my bike would combine 2 of my favorites! Whadya think?
Anthony
