Old 08-23-2008, 12:29 AM
epifanatic's Avatar
epifanatic epifanatic is offline
ha ha charade you are
old Zenith
This thing has been stashed in the laundry room for years, just ran across it while cleaning. Plugged it in and, viola!! works like a charm!! Belonged to my wife's grandfather. Any info on year, value, etc. would be much appreciated.
thanks,
Mike
All this worldly wisdom was once the unamiable heresy of some wise man.~ Thoreau
Old 08-23-2008, 12:33 AM
epifanatic's Avatar
also... any idea what the plug in the last photo is for??
Old 08-23-2008, 02:22 AM
mr_fixer's Avatar
mr_fixer mr_fixer is offline
Worthless, absolutely worthless. thats why you should donate it to me for free, unless Sandy shows up and comments, then I would be guilty of plagerization, for stealing his line. A guy has to try every once and a while, ya know?. As to your question, it is a Zenith Transoceanic early 50's version. Value? only a fair market can determine that, but you could look at completed auctions at that E something or another auction site to give you a ball park idea. that plug was for a battery pack to make it portable, which aren't availble except as a kit to adapt modern batteries to the radio, which you can also find at that E something or another auction site. Logan
Old 08-23-2008, 02:50 AM
epifanatic's Avatar
Thanks Logan.
Old 08-23-2008, 05:10 AM
Dammit Logan...You stole my thunder ! Yep, Zenith T/O, late '40s/early '50s, VERY desirable radio, prolly worth at least a hunnert bux, anyway...Clean the case w/warm soapy water on a spounge, rinse & dry carefully, & then hit it w/a couple of applications of a good black shoe polish...It will GLOW...The dial & buttons can be cleaned w/Windex, Q-Tips, paper towels, but be careful. You've got a Prize, there !
Old 08-23-2008, 05:28 AM
Fisherdude's Avatar
Fisherdude Fisherdude is offline
The Golden Age of Hi-Fi
That's a model G500.
It was considered a "transition" model, in between the technologically obsolete pre-WWII models, and the "all-new" H500 that came later.
The G500 was introduced in Oct/Nov 1949 as a 1950 model, and was produced through May, 1951.
The G500 used miniature tubes instead of loktal, fewer tubes, no selenium rectifier, and featured much longer battery life.
It is considered by many collectors as one of the most beautiful Trans-Oceanics.
Nice find!
I may be growing older, but I refuse to grow up.
Old 08-24-2008, 05:54 PM
sprman55 sprman55 is offline
glowing cosmic energy
Hi nice find.Be very careful i would recap it befor playing it.The 1L6 tube goes high price now days.Be careful on how you clean it to.I had sold it years ago in the 90s.It worked ok got lots of stations.Sprman
Old 09-02-2008, 04:20 PM
k-man k-man is offline
Very nice shape, It's considered to be the best sounding of the Transoceanic radios. Be sure to replace the filter cap, my friend is repairing one that someone plugged in without and the cap exploded! There's lots of info on Transoceanics so restoring it shouldn't be too hard.
Real amps glow in the dark :-)
Old 09-02-2008, 04:25 PM
gadget73's Avatar
gadget73 gadget73 is offline
That dangly plug is for the batteries, which would go into that compartment at the bottom. Probably a 2 or 3 volt "A" cell and a 45 or 67 volt "B" cell.
Random bits of stuff in the collection:
Yamaha YP-D4 turntable with B&O MMC 10E cart
Allied 495 receiver
2 Magnavox amps, AMP150 and an AMP178, currently under the knife.
Onkyo TX-4500
Onkyo Radian III speakers
Old 09-02-2008, 07:10 PM
Randy Bassham's Avatar
The battery pack supplied 9 volts for the filaments which were wired in series and 90 volts for the B+.
KAØSCR
Old 09-02-2008, 07:35 PM
Old1625's Avatar
Old1625 Old1625 is offline
Yep! Got a slightly different model year similar to that one; the speaker grillework is different, but it has the rotary dial just the same. It worked fine up 'til recently; it needs an IF tube to bring it back to life again. When I encounter such tube amongst my rummaging and cleanup campaign around here I will stuff it and listen once again, I'm fairly sure. Yay Zenith!
