Old 09-23-2008, 06:23 PM
Hemingray's Avatar
Hemingray Hemingray is offline
Vintage Geek
Battery vibrator?
Recently obtained a rather old 6v tube car radio at an antique store (uses a large metal vibrator can). I am not getting ANY high voltage for some reason. The vibrator tube is buzzing, but there is no HV at the 6X4 rectifier tube. Any ideas (or where I can find a replacement vibrator, (Mallory type 659 6V vibrator)
Death: Man how old is this TV?, You probably get the DuMont network on this thing!
Old 09-23-2008, 06:37 PM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
www.tubesandmore.com sell solid state vibrator replacements.
Don't tell your wife.
all the best,
mrh
Old 09-23-2008, 08:11 PM
electroking's Avatar
a- v- karma member
The transformer could be open. Check the windings.
Old 09-23-2008, 08:51 PM
Hemingray's Avatar
Vintage Geek
Okay, gave this another try, and it seems that this particular radio has a POSITIVE ground, (was trying to run it as a negative ground). The original vibrator is functional, as is the rest of the radio. (Pics will come later here.) Pulls in clearchannels with great audio.
Tubes are fairly common too, (6BE6, 6BA6, 6AV6, 6X4, 6AQ5)
Old 09-23-2008, 10:08 PM
240sx4u's Avatar
240sx4u 240sx4u is offline
Dynaco convert
Now how could I not check this thread out.
All my gear won't fit in a 275 character sig.
Old 09-24-2008, 09:07 AM
toxcrusadr's Avatar
You and me both!
Change all the caps in that beast, and make sure you get the HV ceramic disk cap across the vibrator. Its job is to round out the square wave into something more sine-like. Probably 1000V or 1600V.
Really cool when you can get one of these going. I've only done one, but it was for a '52 Studebaker that belongs to a good friend of mine who does car shows with his Sea Foam Green Commander V8.
Old 09-24-2008, 11:40 AM
Hemingray's Avatar
Vintage Geek
The pics
Here's pics of this radio. I forgot to mention this was found in West Plains, MO.
Old 09-24-2008, 01:18 PM
toxcrusadr's Avatar
Cool! It's pretty small. I assume all mini tubes?
Old 09-24-2008, 01:40 PM
gladiator335's Avatar
gladiator335 gladiator335 is offline
MRTI
By the thread title I thought it would'n be about radio...
Old 09-24-2008, 02:18 PM
markdi markdi is offline
markdi
This thread needs some explicit nude photos - of the radio.
Old 09-24-2008, 05:51 PM
Hemingray's Avatar
Vintage Geek
ah yes, this I will need to provide too. (I need to recap it anyways)
Old 09-24-2008, 05:52 PM
Hemingray's Avatar
Vintage Geek
Yes. All 7 pin miniatures (6BE6, 6BA6, 6AV6, 6AQ5, 6X4) (have a 6CS6 coming to give it a bit of a reception boost in this area)
Old 09-24-2008, 05:57 PM
Lots of times, if hooked up to a good antenna, those old car radios were/are EXCELLENT DX machines...
Old 09-24-2008, 06:05 PM
a- v- karma member
Unfortunately, this one does not seem to have an RF stage, but with
the right conditions, you can still get a lot of fun. Just out of curiosity,
where did you get the idea of replacing the 6BE6 with a 6CS6?
Old 09-24-2008, 06:40 PM
Hemingray's Avatar
Vintage Geek
The site appears to be down, but http://www.dogstar.dantimax.dk/tubestuf/amtx-1.htm described a single tube AM transmitter using a 6BE6 or a 6CS6.
