Old 10-15-2008, 12:43 PM
www.records www.records is offline
Quality over Quantity
Tubes used in TVs?
What tubes do you guys look for to use in early tube sets? Any rare ones?
Old 10-15-2008, 12:58 PM
I should also point out, my question isn't so I can reap any possible financial gain. So, if you can answer the question, fire away.
Old 10-15-2008, 02:44 PM
Aside from picture tubes, most of them are pretty common. There are a few oddities that show up in early bw sets. I guess 6SN7's and 12AX7's are getting kinda expensive. When you get into 60s color sets there are some sweep tubes that are real expensive these days.
Old 10-15-2008, 04:28 PM
For the most part, it's hard to give away TV tubes at a typical swap meet. Millions are still in circulation and many have no use outside the dinky circle of TV collectors.
There are rare exceptions, but you're not likely to find them in the case where, "Grandpa retired from the radio/tv business and left behind a basement full of tubes."
If you do stumble across Grandpa's basement, I'd be tempted to rescue them because they aren't being made any more. But only if I had ample storage space and didn't expect to make any money selling them for another few decades
Old 10-15-2008, 07:07 PM
This diagram of my 1950 Admiral B&W TV should give you an idea of what to look for.
Old 10-16-2008, 08:06 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
Hi.,
Any TV Sweep tube used in CB Radio and Amateur Radio Linear Amplifiers tends to be high demand and expensive. Those Sweep tubes are expensive and darned hard to find since all of them are NOS and in limited supply.
Old 10-23-2008, 09:41 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
Originally Posted by KentTeffeteller View Post
Hi.,
Some of those CB linears are so poorly designed that tube life could be measured in weeks.
Back when sweep tubes were common, nobody cared, but now, CB'ers have pretty much depleted any large supplies of NOS sweep tubes, especially the 6LF6.
Old 10-24-2008, 12:16 PM
radotvguy radotvguy is offline
mike g
6je6 tubes are rather expensive now a days too
