Old 10-15-2008, 10:55 PM
vytautus vytautus is offline
EH Scott find II follow up
Guys I finally had some time to try and bring up this old monster (The Phantom FM that I posted pictures of back in July.) Well everything went fine on the variac and I was getting static at about 75. Then I went up to 85 and one of the electrolytic caps in the power supply blew. How should I go about replacing these 3 caps is it best to grind out the inside of the cap and insert a modern unit, or should I try to find a serviceable original set of caps? From what I hear, electrolytic caps have a tendency to blow when they get old.
Also what do you guys think of or know about SK-182 Lafayette 12" speakers and University T 210190 horns. I found these 2 old monster cabinets 2.5' X 2.5' X 4.5' with homemade crossovers and these components at my Goodwill. They weigh at least 100 pounds each and look very well built with fancy grill cloth and wood grain Formica covering . Where they a kit? Does anyone remember or know of plans for these being sold in the 1950's or 1960's? I will post pictures later they are in storage they were to big to get into my house right now.
Old 10-16-2008, 01:30 AM
gadget73's Avatar
gadget73 gadget73 is offline
I would leave the old caps physically in place, but disconnected. Install new caps under the chassis if possible. You may need to install a terminal strip to tie the caps in. I'd also suggest replacing the rest of the caps in the set, the paper ones go bad too.
Random bits of stuff in the collection:
Yamaha YP-D4 turntable with B&O MMC 10E cart
Allied 495 receiver
2 Magnavox amps, AMP150 and an AMP178, currently under the knife.
Onkyo TX-4500
Onkyo Radian III speakers
Old 10-17-2008, 03:37 PM
toxcrusadr's Avatar
+1 on that. Nice find!
