Old 11-10-2008, 07:33 PM
NYListens's Avatar
NYListens NYListens is offline
CBGB & OMFUG
Halicrafters S-120 Question
I am in the process of recapping one of these boat anchors. I have replaced all of the electrolytics and almost all of the other caps except the micas and ceramics and it is still has an extreme ac sound to it. Could it be the rectifier? Any suggestions on replacing the rectifier? Can I use two diodes in series, and if so, which type of diode should I use? I also need to replace the Globar resistor and have no idea what I should use.
Vintage System: Fisher 500B, Technics SL Q202 (Ortofon VMS 30), Tandberg 3000X, Denon DCM 290 through a pair of Apogee Centaur Minors
Workshop System: Fisher 500-S, Pioneer PD M-400 through a pair of Acoustic Research AR 8BXIs
New project: overhaul of a Scott 340B
Old 11-10-2008, 07:41 PM
electronjohn's Avatar
I like....big sparks!!
You might try inserting the AC plug in the opposite direction... flipping the plug may eliminate the hum.
Old 11-10-2008, 09:42 PM
markdi markdi is offline
markdi
I bought a nice looking s120 at the thrift store for 3 dollars
yesterday - mine hums a little too
Old 11-10-2008, 10:00 PM
NYListens's Avatar
CBGB & OMFUG
Have you recapped it yet?
Old 11-10-2008, 10:59 PM
markdi
no I have not recapped it.
What is a Globar resistor ?
Old 11-10-2008, 11:20 PM
NYListens's Avatar
CBGB & OMFUG
I believe they are non-inductive ceramic (not wire through ceramic.)
Old 11-22-2008, 10:50 PM
stahlhart stahlhart is offline
Post
The specification on the globar is 680-100 ohm. I have doubts that you're going to have any luck finding a replacement these days.
Why do you feel that it needs replacing? Looks to me that it provides some sort of current regulation for the filament / panal lamp string.
The rectifier is selenium; you could probably substitute a silicon one if you had to, perhaps 1N4002 would work. Two in series isn't going to accomplish anything. It's a low-cost half-wave design, and without a power transformer there's not much you can do to improve on it.
Have you tried another 12AV6? Do you have hum in the audio with the volume all the way down?
