Old 11-11-2008, 05:09 PM
Yuky Tuner 8PT
Here's a few pic's of the tuner that De Oxit won't help. But works on one channel!!!
Terry
Old 11-11-2008, 11:35 PM
If it's sufficiently hopeless that it needs to be replaced, maybe you could make this bad tuner a channel 3 only tuner. Solder the switch contacts permanently to the channel 3 position, and feed this TV set with a DTV converter box set to analog channel 3 output. Analog over the air TV is going away next Feb anyway...
When a good tuner comes around, just replace the channel 3'ed one with it.
