Old 12-16-2008, 03:58 AM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
Broken front glass of GE locomotive style TV
Hi,
I have got a very nice GE locomotive style TV with a broken front glass. Does somebody has an idea whether it is possible to fix the glass, or to make a replica of it?
Kind regards,
Eckhard
Old 12-16-2008, 06:14 AM
radotvguy radotvguy is offline
mike g
ge
thats a fairly common set and they do come up on ebay , keep your eye open and eventually one will pop up
Old 12-16-2008, 11:16 AM
kx250rider's Avatar
REAL TVs have TUBES!
What a coincidence! I had one a long time ago with that exact type of crack. You could get a new piece made by a glass shop, but it would cost about $50, then you'd have to figure out a way to paint the inside of the glass correctly. That was a bad design, with the edges of the glass exposed. It doesn't take much to crack that 2-ply safety glass from the edges.
Charles
Old 12-16-2008, 02:18 PM
Tony V's Avatar
Tony V Tony V is offline
I have one but in my case the glass is missing.
-Tony
Old 12-16-2008, 03:33 PM
Question
Thinking out loud here... Maybe the stuff used to fix chipped car windshields might work for this?
Old 12-16-2008, 04:13 PM
yagosaga's Avatar
VK Member
I have a glazier here in the city who has done some glassworks for me in the past. He probably can make a glass of similar size. But how can I manage the printings and paintings on the glass?
- Eckhard
Old 12-16-2008, 04:47 PM
Old1625's Avatar
Old1625 Old1625 is offline
Any glass shop worth their salt should be able to form and cut that piece of glass. The artwork painted on the back is going to be the major challenge.
But the chief concern I have is that the cabinet itself has probably become unglued at its edges to the point where there is no longer any dimensional stability, and the cabinet is freely wracking with handling, thus the diagonal crack. Put on a new piece of glass, and you'll be fine--until you need to pick up and move the set elsewhere, and you may be back to square one.
The cabinet is probably chock-a-block full of triangular pieces of wood stock in all the inside corners. You need to make sure that all the joint gluings are still intact on these if you want it to keep the next piece of glass you install.
Old 12-16-2008, 10:24 PM
The gray shouldn't be too bad; you could maybe do the striping with some vinyl stripe, or find a sign painter/professional striper to hand paint it on. I'm assuming the General Electric lettering is also painted on the back, and that would be tough. Probably a way to get it made in vinyl, too...that's pretty small for a sign machine.
Old 12-16-2008, 10:53 PM
Tony V's Avatar
The GE emblems are available online so that wouldnt be a problem. Luckily for you guys, you have the glass still so you can make the "Double D" size just right for painting. One good thing is behind the glass theres still the metal bezel that surrounds the tube. I've thought of getting a glass cut and reverse painting it to replace my missing one, i just havent got around to it. Luckily the tv works so i'm ahead as far as that goes. I still dont have the correct knobs for either the tv or the glass, so that has to be taken care of also. From what i heard, most of these glasses got broke from people tightening the two knobs at the top too tight causing the break. Every cracked one i've seen radiates from one knob or the other.
-Tony
Old 12-17-2008, 07:44 AM
merrylander's Avatar
merrylander merrylander is offline
Why not use a piece of 1/4" Plexiglas it won't crack. Then use a software program like FrameMaker or Visio to draw the artwork, color it, and send it to a large format printer. Cut out the printed artwork and set it under the Plexiglas.
Some people are like Slinkies, not really good for anything. They do bring a smile to your face when you push them down the stairs.
Old 12-17-2008, 10:42 AM
kx250rider's Avatar
What a great idea!!!! I'd try it. Only trick will be to get the correct arc on the top. Maybe find a wash tub or something with a circumference that matches the curve, then trace it?
Charles
Old 12-17-2008, 12:09 PM
Adam's Avatar
Adam Adam is offline
I got one of these with the glass cracked on it too, it sounds like not too many of these sets survived with the glass intact.
Old 12-17-2008, 09:16 PM
I second the vote for trying Plexiglas (aka arcylic, Lucite, etc.). Cheap, and easy to work with hand tools, unlike glass.
Or if you're feeling lazy, there are plastics outfits that can make basically anything you want. There is a Tap Plastics store about 10 miles from my house, for example ( http://www.tapplastics.com/ ).
Phil
Old 12-18-2008, 02:12 AM
yagosaga's Avatar
VK Member
Hi to all,
thank you for your numerous replies. I will speak with the glazier, and next, I will try to find somebody, who makes plastics outfits. This might be the best way.
The GE tv set was OK before shipping, but it might be damaged on the way to Germany. Nevertheless, it is a very nice looking tv set.
Kind regards,
Eckhard
Old 12-18-2008, 09:20 AM
Charles
Both Visio and FrameMaker can scale a curve for you, you just need to know the dimension from the center of the curve to a flat line drawn between the end points. Printing is helped if you have a 36" wide DesignJet 350C like mine.
