Old 01-04-2009, 10:40 PM
azguy1878's Avatar
azguy1878 azguy1878 is offline
<--64' Packard Bell
Will sets left alone be worth more?
Lets face it, most of us have sets that have had chassis rebuilds..or at least had a few caps replaced. It seems we're going to come to a point in the near future where it would be hard to find sets that have been "untouched". So my question is this: Do you think that say 20 years from now a set that has never been repaired would be worth more then one that has been repaired, even if the unrepaired set doesnt work?
It just seems that soon a vintage set with the original caps still in it would be nearly impossible to find, hence making it more valuable. at least that is my little theory. The reason I ask is because I have several sets that are virtually untouched, the one in my avatar is a good example, but I know these sets wont last forever without some type of electronic restoration. I would really like to hear your opinions on this as I dont see anything like this discussed yet.
Old 01-04-2009, 11:07 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
From my viewpoint they wouldn't be worth more because I'm not interested in it if I can't make it work. That's if you're talking 20-40 years from now. (As long as I expect to be around)
However, I would find it more valuable if they rebuilt the paper and electrolytic capacitors so they looked original. Of course that might be difficult with black beauties and postage stamp paper caps.
And if I were around a 100 years from now and had money to burn I probably would like a piece of ancient technology where everything was original. Then it would be worth more to me.
How's that for waffling?
Old 01-04-2009, 11:38 PM
Adam's Avatar
Adam Adam is offline
I like to recap all my sets, I'm more interested in seeing if can get all my sets working more than I want them to look 100% original. I watch my vintage sets regularly and before I started recapping them I was taking apart sets I had already fixed for new repairs almost weekly. Although if I ever got a really rare set like a 15" roundie, or a pre-war b/w I might restuff the caps instead of just changing them. It is an interesting idea that there won't be anything left but recapped sets in 10-20 years or so, I would also think that only very new sets and the older sets from the early 70s and back will still be around, probably won't see many sets from the 80s, 90s or today.
Old 01-05-2009, 06:59 AM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
Well, I have two restos under my belt, the 630TS and the DuMont RA-105B. I recapped them completely, but, I saved the old caps and took extensive digital pics of the Chassis, just in case someone (me?) in the future wants to restuff them all and put them back in.
I want them to work, now, and I want them to LOOK new, like just out of the box. My best talents are cosmetic restoration, and I have just enough knowledge of electronics to be slightly less than dangerous, but, I'm getting better.
Thank God for Guardian Angels, here and elsewhere.
I believe cosmetic condition is a bigger factor now, and in the future. But, if you can restore a Set cosmetically, perfectly, so it looks like a Time Machine, it's worth more. Far more. If you come up short in this department, and do a hack job, it's worth garbage...
LJB
Old 01-05-2009, 08:27 AM
RobtWB's Avatar
RobtWB RobtWB is offline
Will virgin, unmolested sets be worth more? I doubt it.
Take vintage autos for example. Even those that are garaged and are for show only need maintenance. Hoses and belts deteriorate, fluids deteriorate etc. Certainly the value of the vehicle does not fall.
I doubt that there are but a handful of truly vintage, virgin, and unmolested televisions and radios anywhere. After all in the 50's and 60's and even into the late 80's there were thousands of tv / radio repair shops keeping these sets alive. It is understood that these sets REQUIRED maintenance, and if done properly the set should not loose value.
Old 01-05-2009, 08:56 AM
Old1625's Avatar
Old1625 Old1625 is offline
I cannot agree with the originality of the contents of the underchassis having an impact on value; the outer cosmetics and the workability of the set should take priority.
Some might get fanatic enough to core out the old cylindrical capacitors and try to stuff the replacements inside to make the underchassis look like it did originally, but I personally could never be bothered. Nobody else besides the techie will care. I will go so far as to leave an old twist-lok can in place, even if it is excluded from the circuitry and axials installed underneath to replace it; I don't favor removing them and leaving the nasty-looking hole in the chassis top. But that's as far as I'm apt to go.
I look at it this way: any changes to a set are part of its long history--all repairs made to it tell a story. That has to be of some value in itself.
One set I've got here, an Emerson seems to have a replacement CRT made by a company that once existed in Springfield, MA--the Crown Company. Has anybody ever heard of them?
Old 01-05-2009, 10:11 AM
electroking's Avatar
a- v- karma member
My 1960 Electrohome still has the factory CRT, with good (not like new, but definitely
good) emission and only a small burn spot in the middle of the screen. As long as
I can keep it going with that tube, it is original enough for me. I believe the tubes
in the tuner are also original, but if they test low I will definitely replace them, so that
the set can live in its intended mode until that dreaded date in August, 2011.
P.S.: Yes, it is the set in my avatar with me watching the blank screen!
Old 01-05-2009, 11:26 AM
zenith2134's Avatar
If the resto was done right (if the tech used quality parts, and didn't cut corners) than it could be worth more IMO.
But if it's all hacked up, someone competent will have to take the time to make it right again, and the set won't be worth much anymore.
But there's nothing like finding a set that has NEVER been opened, or has only had some tubes changed out. Sure, it'll be a project to re-cap the damn thing, but at least it's a prime candidate!
I would pay more for a properly functioning, non-original set than one with a vertical burn line and a smoked flyback because someone decided to keep it 'original'. (as long as 'properly-working' does NOT mean a color Samsung in the chassis' place!!! )
Old 01-05-2009, 11:40 AM
kx250rider's Avatar
REAL TVs have TUBES!
I have to respectfully disagree with most of the above opinions.
A "virgin" nonworking set is far more desirable to me, and also to at least 3 other bigtime collectors with whom I've been acquainted for a long time. In the case of prewar sets, it can bring the value down dramatically if they've been recapped or otherwise disturbed. HOWEVER, with more common collector sets, (i.e. Predictas, 630 TS's, and probably most all color sets, a recap and rendering into working order is fine. One of the very few Zenith 43M20 color prototype 15" sets still to exist is 100% virgin, and has about 2,000,000 Sprague striped Black Beauties in it. That set will NEVER be recapped, although the original screw-head 15" tube is GOOD!
Bottom line: If the TV has already been fooled with, or if it's not really a rare set, go have at it! But if it's untouched, leave it alone and trade it to another collector for a recapped, working set.
Charles
Old 01-05-2009, 11:59 AM
marty59's Avatar
marty59 marty59 is offline
Think of antique radios..something around for 70+ years..same situation. It's always nice to find something that has'nt been molested and even in this catagory there will at least been a time when the electrolytics have been changed in some (haphazard) way if anything. I'm very anal retentive about my work to an artform.. Okay, I don't restuff wax capacitors but someone that takes things to that level I won't fault them either but admire. I do restuff Philco bakelite capacitors and electrolytics...makes things so much neater and makes sense.
I also look at it this way...sometime after I'm gone or someone else owns something of mine I would not want anybody to have to "redo" my work!!
Now with what all we know about electronics, and variations/conditions of, you may understand why you never see old electronics on Antique Roadshow!!
Old 01-05-2009, 12:48 PM
RobtWB's Avatar
So ... Say a collector finds the rarest of the rare, a color prototype perhaps, or even a b/w prototype, or an original, pristine, museum quality CT 100 with the original hang tags and paperwork and bill of sale, or a pre-war set, tucked away in an attic for the past 50 years...What should he/she do??
The answer. Leave it alone. Do NOT remove it. DO NOT change it in any way. Leave it right where it is. Where it has been for the past 1/2 century. Leave it where no one can gaze upon it and marvel at it. But if one must take it, PLEASE, PLEASE, PLEASE DO NOT bring it operational. DO NOT replace any component that is no longer within tolerance, Heck, don't even disturb the dust on the set or within the set, after all it also is a part of the sets history.
Old 01-05-2009, 01:21 PM
I have to agree with kx250rider. Most old TVs and radios got regular maintenance during their service lives. That was part of their history, and if we choose to restore them to working condition, that's their next phase in life. We --and future owners -- can enjoy them working as originally designed.
I make exception only for Very Special sets and leave them untouched. My Zenith TransOceanic 7G605 "Bomber" has never been touched, and I will never mess with it (or play it). Same for the leather-cased A600L TransOceanic which belonged to Joan Fontaine. I will leave it exactly as it was when it left her hands.
http://www.antiqueradio.org/zen32.htm
Even for a common set, I will always pay more for an unmolested original than one that has been newly restored. I would rather do the restoration to my own tastes. Let me be the one to decide whether to restuff capacitors, etc. But maybe I'm just a fussbudget
Phil's Old Radios
Old 01-05-2009, 04:02 PM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
Hi, I have to agree with kx250rider too. An untouched and unmolested tv set is of more value than a recapped tv set. In some centuries, none of these vintage tv sets of today would work. In these times, an untouched set is of the highest value since it is the rarest one.
We have here in the Halberstadt cathedral old clothes which are 800 years old. They are unmolested and untouched, and therefore, they are of highest value. No one could buy them due to the high price. On the other hand, 800 year old clothes which were fixed and repaired are of no value, one can even find them on the fleamarket from time to time for a few dollars.
That's the difference.
Kind regards,
Eckhard
Old 01-05-2009, 04:22 PM
tubesrule's Avatar
tubesrule tubesrule is offline
I'm with Charles on this as well. If the set has already been worked on, or butchered in the past, then there is no question that keeping it in working order is a plus. Most sets from the 1950's on will probably already have been worked on at some point in their lives anyway, so it's just a matter of maintaining the set in good working order.
If the set is something special and is in original condition, than I view this as a plus. Being able to see what the factory original did on an untouched set makes for a nice time capsule. There isn't much sense in redoing a set like the Zenith Charles mentioned when there are other 15" sets that are already in working order if that's what you want. In 50 or 100 years, they probably won't care if the set works or not as they will be far advanced from this technology, so having it original would be of more value.
I have seen many original, untouched cars (including original tires, hoses, spark plugs, etc.) go for very high prices, much higher than restored examples, but it's ultimately up to the buyer and seller to put a value on these things. Many people wouldn't pay a dollar for a car that is basically undriveable, versus one that is fully restored and can be driven anywhere. To each his own. That what makes collecting fun.
Darryl
Old 01-05-2009, 05:18 PM
Old1625's Avatar
Yup!
...But if it's all hacked up, someone competent will have to take the time to make it right again, and the set won't be worth much anymore.
And one could win the lottery, too. Most (I didn't say all!) early sets were bound to have repair work done on them every year or so. While today's sets are by and large crummy 10-year throwaways during those 10 years they usually don't seem to need service. But at the end of that lifespan the set will become no longer operable, or the quality of operation has deteriorated to a great degree. Then you open up the set, and find that the vast majority of the stand-up electrolytics have either puffed up, or pulled up their skirts. One could re-cap the board, and then the next thing something in the power supply lets go. Reliability goes downhill rapidly. The tiny PC assembly is cooked, and every component on it crying out for renewal.
The early sets required regular tweaking and maintenance, and many have lasted over half a century of either disuse, or moderate use and continuous maintenance, or any condition in the continuum between. The reliability of properly-restored earlier sets will be the same now as when they were new. And that is a reliability nowhere near what late model sets give--for about 10 years for most makes.
Amen to that!
