Old 01-25-2009, 02:09 PM
jonboy55's Avatar
jonboy55 jonboy55 is offline
Removing Scotch Tape from a Plastic Radio
I'm trying to remove some scotch tape from a plastic radio. It's brown plastic (not bakelite, etc.) and the radio is from 1952 and the tape has probably been on there for at least 25 years.
Any suggestions?
Thank you.
Old 01-25-2009, 03:28 PM
avionic's Avatar
avionic avionic is offline
Eagle Keeper
Goo-gone
RET USAF 1978-1998
Old 01-25-2009, 04:19 PM
Fisherdude's Avatar
Fisherdude Fisherdude is offline
The Golden Age of Hi-Fi
Originally Posted by avionic View Post
Goo-gone
Just be sure you don't use Goof-Off. It's NOT the same stuff.
I may be growing older, but I refuse to grow up.
Old 01-25-2009, 05:14 PM
guitarslam's Avatar
guitarslam guitarslam is offline
Sonic Moron
WD-40 usually works pretty good at removing scotch tape residue.
Test it first on a "hidden" part of the plastic first though (for compatibility).
HTH!
Glen
Old 01-25-2009, 05:33 PM
JonL's Avatar
JonL JonL is offline
Believe it or not, mayonnaise. Smear it on with a finger, let it sit for a while, smear it some more, it'll start loosening the adhesive until you can finally just wipe it away. Should be safer than the alternatives, even if slower.
Old 01-25-2009, 05:43 PM
batterymaker's Avatar
Repro Battery Builder
GOJO white hand cleaner. WITHOUT pumice. Excellent at removing petrified masking tape.
Old 01-25-2009, 11:23 PM
Old1625's Avatar
Old1625 Old1625 is offline
A lot of these non-abrasive mechanic's hand cleaners are mineral spirits based. Mineral spirits alone is good at removing the residual adhesives of "scotch" tape. And seldom in my experience will hurt bakelite or even older wooden radio cabinet finishes.
The solvent cannot readily penetrate the surface of the tape to get to the adhesive underneath to dissolve it, so the chief ingredients other than the mineral spirits are extreme patience, and one heckuva strong fingernail. One thing in your favor is that by this point that tape must be pretty aged and brittle....
The mayonnaise trick mentioned is the first I've heard of such.
Old 01-25-2009, 11:49 PM
Twenty20Man's Avatar
Twenty20Man Twenty20Man is offline
Misty
rub it off with day old bread...
"Common Sense isn't quite so common anymore"
SX-1250,1050,1010,939,838 x2, 737,636
CR-3020 CR-2020 x2,1020 x2,820
Concept 16.5,6.5,KR-7400
Thorens TD-145 Mk II
Yamaha CDC-715
KLH,Advent
Old 01-26-2009, 06:58 PM
Or a day old sandwich, that way you get the mayo too! LOL
Old 01-26-2009, 08:53 PM
jonboy55's Avatar
Fortunately, I was just having a baloney on rye with mustard. The mustard worked great!!
Also, a little rubbing alcohol didn't hurt.
Old 01-27-2009, 08:50 AM
Glad you got it, but be careful with rubbing alcohol. It can craze the finish on most plastics.
