Old 01-25-2009, 07:50 PM
Bargain in TV Parts
I can assure you I have nothing to do with this evilbay ad!!! But jump on them quick before someone else does!!
(Not that theyr're such a bad part, I've never seen this type of item priced so high, as they are usually found in a 25 cent box at any hamfest-and never any takers))
http://cgi.ebay.com/VINTAGE-tube-rad...A11%7C294%3A50
julian
Old 01-26-2009, 12:55 AM
AUdubon5425's Avatar
Oh boy - you can even rewind them!!!
AUdubon5425 Youtube Channel
Old 01-26-2009, 11:20 AM
vintagecollect's Avatar
1977 Zenith Chromacolor II
A Very Modern Zenith
Old 01-27-2009, 02:06 PM
They would come in handy for my CTC 4 and some others I have but man, 50 bucks is a bit much for my budget right now for something that will certainly sit around for a while. Maybe he will lower the price if there are no takers.
Old 01-29-2009, 03:40 PM
Not to burst anyone's bubble, but I'm inundated with some similar inductors. They are actually transformers in my case - 5 connections, two of them go to the inner coil, and three connect ot the outer coil. They could be re-wound, for sure. They are about 1.65" long overall, and have a hex adjustable core inside. I've got about 80 or so. Free to good home - just PM me, and they are yours for the postage.
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 01-29-2009, 05:12 PM
PM sent.
Old 01-30-2009, 11:03 AM
Free? Free?? You mean like FREEEEE??? But I saw them on evilbay for $60! (Old worn out cliche that I'm sick of hearing!)
When at any meet and find goodie parts, I always pick them up. Unfortunately, parts are not good sellers anymore for the simple reason young people are not involved and complete units are far cheaper than building anything and the majority of electronics people (newer generation-not us old fogies) don't know how to build/fix/engineer stuff anymore. Loopsticks are not made anymore because they contain copper coils like transformers and are not engineered because they are "engineered out" of todays' digital circuits. However you can still find a fairly good supply of most (and other parts) at any good hamfest and they are nowhere near evilbay prices! Many are giveaway to a good home.
I can remember the time that I ordered out of Allied, Olsen, Burstein Applebee and Lafayette catalogs for parts to build test equipment and small radio gear because I could not afford $20 for a similiar unit! I can't tell you how few lawns I mowed for $3 (they were also hard to find too) to buy these parts and took care of what I had.
julian
Old 01-30-2009, 02:21 PM
Originally Posted by julianburke View Post
Free? Free?? You mean like FREE??? But I saw them on evilbay for $60! (Old worn out cliche that I'm sick of hearing!)
I can remember the time that I ordered out of Allied, Olsen, Burstein Applebee and Lafayette catalogs for parts to build test equipment and small radio gear because I could not afford $20 for a similiar unit! I can't tell you how few lawns I mowed for $3 (they were also hard to find too) to buy these parts adn took care of what I had.
If I could get to a hamfest I'd look for a 1-megohm dual potentiometer to replace the defective one in my Zenith MJ-1035 radio; these parts can't be found anywhere else, I'm afraid. I haven't been to a hamfest in over ten years because I don't drive.
Julian, I was very surprised to read in your post that loopstick antenna coils are no longer manufactured. These coils were, at one time, very popular in transistor radios and even mounted on the back covers of expensive stereo hi-fi receivers. If new-in-box loopsticks cannot be found these days, what do today's AM radios use as antennas? I know many small FM receivers use the headphone cord as an antenna (I have an FM scanning radio that uses the headphone cable this way), but what about the AM sections of today's cheap plastic AM/FM radios? They have to be using something as an AM antenna; maybe they use the same headphone cord for that band as well as for FM.....?
Sixty bucks seems to me to be an awfully (even ridiculously, IMHO) high opening bid for a small collection of 50+-year-old loopsticks. I think this seller is either very new to eBay or else just wants to get as much money as he can from the sale, not unlike so many other eBay listings I've seen for radios in such bad shape they are useful only for parts. I've also seen eBay listings for radios that state the unit is "for parts only" (with a very unrealistic opening bid in some cases), when the item description clearly states that the only thing wrong with the set is a dry-rotted line cord, a bad tube, or some other easily-repaired problem.
My best guess is that many (or even most) of these listings are posted by people who know little or nothing about radio, TV or electronics, and think that just because a radio or TV is 50-odd years old and has a defective line cord, bad tubes, or other small problems, it is junk. This may well be the case with the seller of those loopstick coils. The person posting this listing may not know what he or she is looking at, but regardless wants to get top dollar for them. The condition of these loopsticks, moreover, is unknown. They are listed as "new old stock", but after having been sitting around who knows where for who knows how many years or decades, the windings may be defective or shorted, the cores are probably brittle as all get out....I wouldn't trust them in any circuit I was building, experimental or otherwise, or as a replacement for a loopstick in one of my vintage transistor radios, without testing the windings with my ohmmeter first. Again, in my opinion, they are not worth $60--the final bid may be, Heaven forbid, much higher (!), but they are certainly not worth anywhere near that, IMO (however high the final bid may be), either.
Good grief.
Old 01-30-2009, 05:06 PM
Originally Posted by Jeffhs View Post
...I think this seller is either very new to eBay or else just wants to get as much money as he can from the sale, not unlike so many other eBay listings I've seen for radios in such bad shape they are useful only for parts. I've also seen eBay listings for radios that state the unit is "for parts only" (with a very unrealistic opening bid in some cases), when the item description clearly states that the only thing wrong with the set is a dry-rotted line cord, a bad tube, or some other easily-repaired problem.
My best guess is that many (or even most) of these listings are posted by people who know little or nothing about radio, TV or electronics, and think that just because a radio or TV is 50-odd years old and has a defective line cord, bad tubes, or other small problems, it is junk....
These types usually don't bother me, but sometimes they cross the line. I have a simple ad on CL "seeking old radio & tv equipment & parts" and some anonymous person posts this:
All those considering giving away old vacuum tubes and electronics containing them: these things are going for a FORTUNE online! Vacuum tubes can bring HUNDREDS of dollars each for certain ones. Before you give away what someone will sell for big $$, look into selling it yourself.
SOME 'might' be 'hobbyists', but there's a lucrative market out there for old tube electronics- and people pretending to be 'collectors'( who are really dealers) to get things free to resell really make me sick.
Mind you, I never asked for anything for free, but this kind of crap fuels the notion that anything old is worth a fortune...
Old 01-30-2009, 05:24 PM
[QUOTE=Jeffhs;2455098]
Julian, I was very surprised to read in your post that loopstick antenna coils are no longer manufactured. These coils were, at one time, very popular in transistor radios and even mounted on the back covers of expensive stereo hi-fi receivers. [QUOTE]
Let me reword this a little. They are no longer manufactured and stocked like they were 30 or more years ago. However some new equipment may require this type of part and it would have to be made on special order or inhouse of the factory making the product. But your local parts jobber won't be carrying them and many other parts for that matter. It would then have to be special ordered. Today, anything made up of any copper is thoroughly revisited. (meaning how can we make it cheaper if we even need it at all?)
As long as they are kept dry, they will survive for many, many decades as they don't deteriorate like many modern plastics and the wire is good for a lot longer.
My local parts house has deleted most of the parts we WERE accustomed to seeing stocked. They have mostly become a computer parts place such as CAT/5 cable and such. The other day I walked in and expected to find an "L" pad. Guess what? Let alone not have one, the new guys didn't even know what it was!
I still need an 8 ohm L pad.
julian
