Old 03-01-2009, 10:56 AM
ihmeyers ihmeyers is offline
721TS Video Size Issues
OK, well I got the replacement (s) for the 6SN7GTB I broke in my 721TS Now I've got synched video again but it fills roughly half the screen and I can't get it to fill any more than that using any of the controls and/or adjusting the magnet on the CRT. Anyone have any ideas? I'd hate to just leave this one in the garage since it's such a cool set.
Thanks!
Old 03-01-2009, 11:16 AM
Tony V's Avatar
Tony V Tony V is offline
Its time to recap the set
Old 03-01-2009, 01:54 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
Oh, God, Yeah.
Complete Recap. Micas, too.
...and watch the Voltage ratings on some of those Micas. Some are 1000 volt rated. Tight tolerances, too.
LJB
Old 03-01-2009, 02:49 PM
I think it was done (at least to some degree) when I bought it from Vaughn. I have never attempted a re-cap myself. I have to decide whether or not I think I can do it. Though I guess compared to the public as a whole I am handy, compared to most on this forum I am much less technical and have no formal training...
Old 03-01-2009, 03:38 PM
Tony V's Avatar
You said you bought it from Vaughn 15 years ago and have had it in storage the past 5 years. Thats more than enough time for even replaced capacitors to go leaky from non-use. If he only particially recapped it (such as just replacing the filter caps) to just get it functional, then you got to look at it like its never been done as there are still 60 year old caps in there. It needs to be gone thru just as LJB mentioned. If your unable to or feel incapable of doing this yourself, there are a few restorers in Fla that may be able to do this for you. If you dont feel comfortable doing anything besides replacing tubes and adjustments..its best to just leave it alone. There are several parts in that set that are no longer available or extremely hard to get and by running it in its current state isnt safe until it gets checked out. Good luck!
-Tony
Old 03-01-2009, 05:34 PM
The key is to do only one cap at a time, ie, remove a cap, and install the replacement immediately afterward. So you don't lose track of where it connects to.
Wax paper caps must be replaced, all are bad. Their life is something like 25 years, and the last time anyone manufactured them was about 45 years ago... Moisture gradually gets into the cap, and the moisture with the acid in the paper corrodes the metal foil and causes leakage paths.
See http://www.geocities.com/wa2ise/radios/repair.htm and http://www.antiqueradio.org/recap.htm though I would not try to remove all of the old cap's wire lead from terminal strips, tube socket lugs or such. Those are fairly fragile, and not designed to take much mechanical stress and strain. J hooks are fine if done neatly (so the joined wires form a reasonably straight path).
Old 03-01-2009, 07:04 PM
M3-SRT8's Avatar
Speaking of 721TS's...
Anybody have a line on a nice, cosmetically very good/excellent one, that's un-restored?
LJB
