Old 03-15-2009, 09:04 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Question Stuck Ferrite slugs
Any suggestions on how to adjust frozen ferrite slugs? It appears that the wax has melted and glued the slugs to the coil forms. I have the proper alignment tools. I learned the hard way years ago not to improvise here.
Should I try a hot air gun or just let the set run until things get hot enough to free up, if ever?
I might not need to do an alignment, but wanted to start thinking about it in case I do need one.
Old 03-15-2009, 09:25 PM
edison64's Avatar
edison64 edison64 is offline
THE A-1 WIRELESS MAN
Location: NW INDIANA THE MAPLE CITY LA PORTE (GO SLICERS)
Used this trick many times, if its an allen type, iinsert the right size metal allen wrench short end first, then heat with a lighter about 10 seconds (STOP)! wait a couple seconds and try to turn. if this doesnt work after a couple tries the form may have swoellen around the slug and then it may never turn.
RCA VICTOR and its dealers bring you......
Old 03-15-2009, 09:42 PM
jeyurkon's Avatar
Thanks for the suggestion. These have a flat screwdriver slot in the ferrite bottom and on top a threaded brass rod with a slot. Maybe I can heat the threaded rod.
Old 03-15-2009, 10:31 PM
Might not take much heat-last one I did responded to one minute with a cheap hair dryer. You have patience so you should be fine!
