Old 10-15-2002, 11:50 PM
Captain Video's Avatar
Captain Video Captain Video is offline
Smile How reliable are old UHF converters?
Hi, I was considering purchasing an old tube type UHF converter from the 1950's to use with my vintage TV. I was just wondering if it´s a good idea - are these things any good? I would really be able to pick up UHF channels with such a device?
Old 10-16-2002, 12:09 PM
Marlin Mackley Marlin Mackley is offline
Hi Cap:
I have to confess I probably have 40 various versions of those converters and have never fired any of them up! Given that most of them are one tub-ers they can't be too hard to get working, and I would be willing to bet that there would not have been so many made if they did not work. How about it, anybody out there actually USE one?
Marlin
Old 10-16-2002, 12:19 PM
Steve K Steve K is offline
Hi:
I have used the UHF converters in the past with good results. Assuming you have a good antenna most should work about the same. The two that I have used most often were the common Mallory model and a rather large wooden RCA converter.
Steve K
Old 10-16-2002, 12:23 PM
Rob Rob is offline
Banned
I tried one of those one tuber's, a Blonder Tongue 99 on my CTC-20 color set and it worked but had bad contact issues in the tuner mechanism. I pulled the chassis out (2 screws and remove the pull off knobs) and sprayed isopropyl alcohol in it and the wafer in-out switch while working the controls. After thorough drying I then I applied WD-40 to the tuner sliding contact with a Q-tip. Put the thing back together and all the intermittent issues had disappeared. I get the impression it needs a good strong signal to work well (I used my tower antenna with tower mounted amp) and got good reception. Kind of a pain to use though, but it was a way back then of opening up a new horizon so to speak. There were better ones made with more than one tube, some sporting RF gain stage which would be better.
Try it!
Rob
Old 10-17-2002, 12:33 AM
Smile
Thanks guys,
Your answers made my mind. I'll go for it and buy a converter.
Old 10-17-2002, 05:14 AM
wvsaz
Guest
Posts: n/a
Hi,
I have used and repaired several of these converters. When they were new, performance was often poor due to the combination of low transmitter power at the UHF TV station, and the high noise figure of the diode mixer in the converter. Today, most UHF stations use much higher power levels, so performance of the converter is usually pretty good. If you do encounter very weak, noisy reception even on strong signals, the diode mixer is a likely culprit. Look for a small brown cartidge in a clip in holder, usually located on top of the chassis. The diode can be snapped out of the holder. You can use a 1N82A diode for a replacement, often with a phenomenal improvement in performance. Of course, make sure the tubes are good. Good luck!
Old 11-23-2003, 05:01 AM
rossj
Guest
Posts: n/a
uhf converter
Hi guys just a short note to let you know i had a mallory uhf converter shipped out to Australia (got it on ebay)It works however it produces a very weak snowy picture, l also had to get a power downconverter as we run on 240v.anyway it looks good on my vintage tv.
Old 11-23-2003, 08:06 PM
I've had decent luck with the tube type convertors; I have a few solid state models from the 60s that tend to drift and things like that, bad contacts,again. The Mallory that is on my Transvision works fine as does a Blonder-Tongue I have hooked up to another set.
Old 11-23-2003, 09:05 PM
heathkit tv
Guest
Posts: n/a
Once broadcast television goes all digital (whenever the hell that happens) I foresee the return of converters that sit on top of of your set, but this time they'll be digital to analog.
Anthony
Old 11-23-2003, 10:30 PM
That's already here, it's called Satellite TV!
Oh yeah, Digital Cable too
Anthony
Old 11-23-2003, 10:36 PM
heathkit tv
Guest
Posts: n/a
Sheddup Beavis :-)
Actually not everyone has either of those (or are cheapskates like me) so I believe there will be a market for such a converter.
Anthony
Old 11-27-2003, 08:04 PM
I went from analog to digital cable shortly after learning that all television broadcasting will be digital by 2006 or, as Bryan said in his last post, "whenever the (expletive) that happens . . . " I have an RCA XL-100 19" TV set that works well for me; I just purchased a 3-year service contract on it and don't want to have to junk it just because everything will be digital (yeah, sure--and I'm the king of Siam; we all know how slowly the government works) in two and a half years or so. One of the technicians from Comcast cable recently told me, however, that the FCC cannot completely outlaw analog TV, because of the sheer number of analog televisions (in the millions in this country alone) currently in use. The cable companies realize this full well, which is why Comcast (and most other cable operators) will provide digital-to-analog converters on a lease basis to subscribers with analog TV sets. In addition to wanting to be ready for the change to all-digital, whenever that comes (!), I went to digital cable because two of my favorite cable channels (Game Show Network and the National Geographic Channel) are now exclusively on Comcast digital cable and are not available on the analog service.
Old 11-27-2003, 10:43 PM
wvsaz
Guest
Posts: n/a
Anthony
The FCC is prepared to delay the shutdown of NTSC transmissions until digital set penetration in the marketplace reaches 85%. Some are predicting that will not happen for perhaps 15 years. The incentive for trying to make it happen sooner is that the FCC wants to auction off the old channels for other uses, and that monetary income will be delayed until NTSC is shut down. $$$$
Old 11-27-2003, 10:51 PM
I went to DirecTV because Cable was so F--ing unreliable!
I figured if the cable co. couldn't get an analog signal to my set they probably coudn't get a digital one to it either.
So far I have been quite happy with DirecTV, other than a minor quibble with excessive compression on some channels, it has a good picture.
It also has a channel 3 output that works great with vintage sets!
Old 11-28-2003, 01:12 AM
heathkit tv
Guest
Posts: n/a
What I find most annoying about cable (and probably satellite too) is that all the channels seem to be at different volumes.
Broadcast television is bad enough, what with commercials that'll blow your toupee off, but cable seems to be far worse, and there's really no excuse for it When the feed comes into the cable company's facilities they surely need to process it in some manner, wouldn't it be relatively simple for them to somehow even out the level of volume?
My late model Sony set has something called Steady Sound which is a miserable crock of poo as it actually somehow raises the volume of music and pulls voice levels down lower. When I bought the set I had high hopes that this feature was going to give me even volume----some other brand was advertising such a thing a little while ago (Philips?)
Anthony
