Old 03-31-2009, 10:44 PM
radio nut's Avatar
Born in the wrong decade
crt testing
I have a chance to get an early color set with the round crt. I tried testing the crt but it is acting unusual. all the guns check really good at first. If I leave the tester hooked up keeping the filaments lit and wait about 10 minutes and redo all the tests the emissions are lower than before. My tester is a b+ k 465. the scale goes to 1,000. At first all the guns check at about 900. Later they all run about 600. That is still in the good range but is this telling me the tube is questionable or my tester is dying? there are no shorts and it still passes the "life test". This is the only crt I have checked that does this. Thanks, Doug
Old 03-31-2009, 11:36 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
It sounds like they all test the same in any event. That's good because you want them to be in balance. 600uA is still pretty decent. As tempting as it is to hypothesize why it's doing this, I'll refrain.
But, I would check for shorts again after you observe the lower emission. Also, recheck the filament voltage setting to see if it's drifted.
Also, while you're checking the emission observe the gun area and see if you see a blue glow that might indicate that it's gassy.
How's the G1 cutoff? With such a high initial emission I'd expect it to be well within range.
I don't think I've been very helpful, but you made me curious.
Maybe you should repost in the color tv forum.
Old 04-01-2009, 12:03 AM
My guess is it's the tester fading after being left on so long.
I doubt it was meant to be left on for 10 minutes straight plus it's old enough it could need some servicing itself.
I have a 465 but I like the 466 better.
Old 04-01-2009, 02:06 AM
jeyurkon's Avatar
I have a 465 also and there's not much in there to fade or fail. There are two electrolytics in the power supply and two in the restore function that should be replaced or tested.
If this behavior still doesn't occur for other CRTs then I'm not as sure that the tester could be failing, unless you see the filament adjust drifting.
Old 04-01-2009, 09:37 AM
John Folsom's Avatar
Why not measure the filament voltage with a meter as the CRT is being tested? It is possible the filament transformer in the tester is heating up and dropping the voltage.
John Folsom
Old 04-01-2009, 05:45 PM
akent36 akent36 is offline
Don't leave the tube on the tester at zero bias for any length of time. It will cause the emission to slump and could damage the cathode.
Old 04-01-2009, 06:41 PM
John Marinello's Avatar
<-- "Byron"
If you start from cold, do the readings return to 900?
If not, then my guess is the tube was rejuvenated.
Old 04-01-2009, 07:39 PM
radio nut's Avatar
Well, I think I will be ok. I recapped the tester and now the guns check as follows. Blue holds at 920, green at 940 and red at 870. They now just sit there and do not change. I wonder now if the problem was caps starting to get weak and the extra transformer load of running three filaments at the same time on my tester.Now I will have to retest my b&w crts and see if they change from what I remember. Thanks for the tips, Doug
Old 04-01-2009, 07:40 PM
radio nut's Avatar
I forgot to add, no blue glow on the tube and the G1 cutoff was 40 volts.
Old 04-01-2009, 08:53 PM
radio nut's Avatar
I went ahead and rechecked my last b&w crt that I had tested.It now checks 100 uf higher than before.Wow!
Old 04-01-2009, 10:56 PM
jeyurkon's Avatar
The color CRT was probably drawing 1.8 amps instead of 0.6 amps, but that shouldn't have cause a huge drift.
The electrolytics were probably increasing in leakage as they warmed up dropping the HV used for the emission test.
Congratulations on figuring it out and repairing your tester.
Did you get the set?
Old 04-02-2009, 10:35 PM
radio nut's Avatar
I had to. I have wanted a tube color set for long time. I would probably push an old lady down a flight of stairs for a set like this.I do like new technology, don't get me wrong, alot of people feel that the tube stuff is junk or outlived its usefullness. I on the other hand am drawn too it. I have placed a tubed b&w set on a stand in front of a perfectly good big screen set and watched it.
