Old 10-21-2002, 05:50 PM
wiseguy wiseguy is offline
Lightbulb what is it????
i know this may not be the place to ask about transmitter tubes,but anyone know what this large tube was used for??
(5948A..)
terry
Old 10-21-2002, 06:20 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
WOW that thing is bigger than an 813 tube! During WW2, the duds were probably used as projectiles to take out the enemy!
Charlie Trahan
Old 10-22-2002, 07:46 AM
wvsaz
Guest
Posts: n/a
That tube is a 12 Megawatt Thyratron - 25 KV peak anode voltage, 1000 Amps peak current. Not a transmitting tube; definitely an industrial type, perhaps used by electric utilities.
http://www.tritonetd.com/product/thyra.html
Old 10-22-2002, 07:50 AM
tube
what were these used for..??
I thought for sure it was a transmitter tube of some sort..
terry
Old 10-22-2002, 08:03 AM
wvsaz
Guest
Posts: n/a
Thyratrons are used for a broad spectrum of high power switching applications such as medical lasers. The thyratron is an electronic, repetitive "on" switch used to generate trains of high voltage energy; accurately timed and precisely spaced pulses.
Old 10-22-2002, 08:54 AM
ckelly's Avatar
ckelly ckelly is offline
That's a monster
I think those are used to heat rooms in extreme cold weather
Old 10-22-2002, 10:13 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Where's Rob? Looks like something he uses in his tesla coils.
Old 10-22-2002, 01:17 PM
Charlie's Avatar
On Land
In the movie Back to the Future , what was the device in the car that made it travel thru time? Maybe I could wire a 5948A into my Galaxie 500 and go back in time!
Charlie Trahan
Old 10-22-2002, 04:31 PM
Flux Capacitor
Charlie,
that was a Flux Capacitor, easy enough to obtain, but where are you going to get the 1.21 Jigawatts (or is it Gigawatts?) of power needed to operate it?
Also If you go looking for Plutonium these days you will certainly wind up in jail as a suspected terrorist!
Your Galaxy 500 is also heavier and isn't made of Stainless Steel so it might actually take a bit more power than that!
If you have the 390cu engine with a 4 bbl carb getting up to 88 mph shouldn't be a problem. Getting it stopped in a reasonable amount of time with 4 wheel drum brakes might be difficult however
Can you tell I saw this movie 13 times in while it was in the Theater
Eric
Old 10-23-2002, 11:26 PM
ckelly's Avatar
Re: Flux Capacitor
Originally posted by Eric H
Charlie,
Eric
Doesn't thor have that many watts?
