Old 07-01-2009, 05:30 AM
Nice Philco on ebay
I wish I was closer
http://cgi.ebay.com/1950-Vintage-Phi...3A2%7C294%3A50
Old 07-01-2009, 07:11 AM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
It appears to be in nice condition.
There seem to be quite a few sets showing up in Michigan recently. Maybe it's our poor economy.
Old 07-01-2009, 01:07 PM
RDusel RDusel is offline
Wow, that is a beauty. Wish I was close as well.
Old 07-01-2009, 04:29 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Reminds me of the HOWDY DOODY philco that was bought by a member here.
Steve
Old 07-01-2009, 04:37 PM
My grandmother had one of these in 1951:
Old 07-03-2009, 05:42 AM
I like the curves of the cabinet .
The seller doesn't think the channel knobs are original , they look like it to me ?
Old 07-03-2009, 08:17 AM
hposter hposter is offline
hposter
Yes, the knobs are original. It's the typical soft-plastic knobs and the painted aluminum (?) channel selector.
To Mr. Tube TV...these are actually fairly common. Depending on your location, you should see one of these at a local meet, or on ebay, closer to you, if you keep looking.
Harry
Old 07-03-2009, 10:11 AM
Tony V's Avatar
Tony V Tony V is offline
I have the square cabinet version. Although a difficult restoration because of all the bumble bee's, i was rewarded with a nice picture afterwards.
-Tony
Old 07-03-2009, 11:17 AM
-Tony
I've been holding off on restoring my 50T-1401 for that reason. Glad you got your working.
Old 07-03-2009, 01:38 PM
stromberg6's Avatar
Unhappy
Has anyone had the tuner in one of these draw excessive current after warmup?
I have a 10", and a 12", and both have this problem. Picture fades to blank raster after about 7 to 10 minutes.
Kevin
stromberg6
Old 07-03-2009, 04:41 PM
Originally Posted by stromberg6 View Post
Has anyone had the tuner in one of these draw excessive current after warmup? Picture fades to blank raster after about 7 to 10 minutes.
I'd check any caps that are filtering the AGC line. AGC control lines are high impedance, and any leaky capacitors will overwhelm the AGC and cause the tuner and IF strip to cutoff. As you mention excessive current, this cutoff is likely due to the RF and IF stages going fully saturated. AGC voltages are usually negative voltages of a few volts, and more negative voltage reduces gain, and a lower negative voltage gives more gain. 0V would be higher gain, or saturation of the tube amps severe enough to not allow any RF or IF frequency to get thru.
A crude test would be to measure the AGC voltage when the set is first turned on and operating normally, and then watch to see if the AGC voltage changes as the signal gets lost. Then you could impose an external voltage on the AGC line the same as the good AGC line voltage to see if you get reception back.
Old 07-03-2009, 04:54 PM
electroking's Avatar
a- v- karma member
A pity that the seller appears to be well on his way to parting out this
set. The question from a potential buyer 'just wanting the cabinet to
display in a nursing home' is appalling. Let's hope this finds a good home.
Last edited by electroking; 07-03-2009 at 05:01 PM. Reason: corrected spelling (again...)
Old 07-03-2009, 09:25 PM
stromberg6's Avatar
Smile
Thanks for the suggestion wa2ise. I'll do just that.
Kevin
stromberg6
Old 07-04-2009, 04:32 AM
AUdubon5425's Avatar
Appalling in another way too - I can see some poor soul trying to turn the knobs, which are glued to the cabinet...
Old 07-04-2009, 10:41 PM
jeyurkon's Avatar
Did anyone here win it?
