Old 07-04-2009, 07:18 PM
miniman82's Avatar
First Light: 1952-2011
Halolight fix?
Just started work on the Halolight I got from Mark (zenithfan1), it's a model 377 which has a dark cabinet with double doors.
Chassis produces a raster after replacing one bad rectifier so I'll recap it, but the halolight light tube is shot. Don't suppose there's any way to revive one of these, is there? The supply has enough power to light up a 40 watt bulb from my ceiling, but nothing from the tube in the set. The tube will light up if I hit it with whatever voltage is going to the picture tube from the high voltage supply, so it does work if you get enough juice to it. My guess is it's gonna be either find a way to get more voltage to the tube, or have a new one made at a neon sign place or something like that? Could there possibly be spares???
Old 07-05-2009, 10:25 AM
Old 07-05-2009, 10:49 AM
RobtWB's Avatar
RobtWB RobtWB is offline
Is the bulb a fluorescent or a neon?
Where is it getting its power from?
True neon bulbs/tubes require significant voltage from a transformer to "light".
Old 07-05-2009, 11:55 AM
holmesuser01's Avatar
Most of these sets that I have seen over the years have a fried transformer on the Halolight power supply.
It IS similar to a neon tube. The light increased and decreased with the video signal. I've never seen one actually working. It would be a nice thing to see.
Old 07-05-2009, 03:51 PM
Can you post some pics? Even though it was my set, I've never seen the inner workings of a Halolight. Might be easier to come up with ideas. Glad to hear you have a raster. Keep us posted Nick.
Old 07-05-2009, 05:32 PM
Dan Starnes's Avatar
Gizmo Nut
Well, I cant help fix, but here is one in action today.
Old 07-06-2009, 01:38 PM
miniman82's Avatar
A small neon sign power supply might be able to make it light.
I like that idea, they make significantly more output than the stock transformer does. Mark, it had a raster after replacing what I though was a bad 5U4, but after going back and looking at the tube, it was just installed wrong- they key thingy on the bottom had broken off. It still worked, but since I have umpteen bazillion of 'em, I tossed it to avoid future disaster.
It's now completely recapped (the 'lytics were good! ), but I can't get horizontal to lock at all. Nice bright raster, but no matter what I do, it won't stabilize. I need a schematic to go any farther with this one, who's got it? It's model 377. Near as I can tell, there's something wrong with either the sync seperator, or maybe horizontal still, but a bright raster and controllable horizontal makes me think sync.
Old 07-06-2009, 04:47 PM
Check for a week solder joint in the sync circuit .
What year is it ? , I might have a schematic ?
Old 07-06-2009, 07:31 PM
miniman82's Avatar
No clue what year it is, I didn't find any markings. Would the chassis number help? If you can tell me where on the chassis to look, I'll find it. There are lots of numbers there, I just don't know which one is which. I'll look for bad solder joints too. I don't know what it is they used back then (100% lead?), but it sucks. Takes at least a 40 watt iron to melt the stuff, but even then much of it flakes off. Can't imagine it conducts very well at all.
I rebuilt everything in the high voltage cage as well, including replacing all HT wiring, cleaning, recapping, ect. When I first fired it up afterwards, one of the 5U4's red plated and melted. I had mistakenly connected a 'lytic and a mylar in parallel with each other on a B+ line , so..... hope the schematic shows HV in detail, but since it shows a strong raster I'll assume things in there are OK for the moment.
Old 07-06-2009, 09:49 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
The chassis number for your set would be 1-518. The Sams folder is 229-15.
I don't have that one, but I have info for the 1-508 which might be close. Or it might just be more confusing.
Old 07-06-2009, 11:25 PM
miniman82's Avatar
Anything you got will probably be helpful, I had an incorrect schematic for the Philco but enough of it was there to help me out with some gremlins. 1-518 sounds familiar, you got a scan?
Old 07-07-2009, 12:39 AM
If all else fails I wonder if a string of white LEDs inside the mask would make a decent substitute for the light?
I had an HL once, it was really beat but the light worked, so did the set sort of but the CRT was shot.
I finally tossed it, I hung on to the bulb and transformer for a while but finally chucked it to, this was before the internet and eBay of course.
Old 07-07-2009, 06:46 AM
jeyurkon's Avatar
I can try scanning it this evening.
Old 07-07-2009, 09:45 AM
jeyurkon's Avatar
Here's a scan for the 1-508.
Old 07-07-2009, 10:50 AM
pallophotophone pallophotophone is offline
Hi,
Any neon sign shop can repair your tube. Replace the electrodes, evacuate and replace the gas.
Bob
