Old 07-07-2009, 06:14 AM
andrefranc andrefranc is offline
VK Member
Installing a phono jack
How can I install a phono jack in a radio that doesn't have one? I tried connecting the center part of the jack to one side of the volume control and then the other side of the jack through a .05 cap to ground and that doesn't work. Do I also need a switch or what? I'm working on a Motorola model C16P.
Old 07-07-2009, 07:43 AM
Tom Bavis's Avatar
Audiophool
This is a transformerless radio - non-isolated from AC line - so I would not recommend connecting anything external to it. If you have a radio with a power transformer it would be a better candidate.
Old 07-07-2009, 10:37 AM
VK Member
There are many transformerless radios with phono jacks.
Old 07-07-2009, 02:15 PM
Reece's Avatar
Reece Reece is offline
You were on the right track to install a phono jack. The manufacturer would have installed a switch to select between radio and phono, but you could get around that by using a closed-circuit 1/8" miniature phone jack as in the circuit below. For radio operation, the detected signal comes to the jack on the green wire and then to the volume control on the red one. When an external audio source is plugged into the jack, the jack opens the green radio circuit and sends the audio signal via the red wire to the volume control.
Back in the day, nobody bothered about making the phono connection idiot-proof and so on AC/DC sets the shield connection of the jack could have been connected to chassis ground as shown and therefore "hot" depending on which way the power plug was in the receptacle. Today you'd want to put an .05 or so mfd. cap between the shield connection of the jack and chassis ground, the jack being insulated from the radio chassis in some way. I'd also run audio wiring like this in shielded cable under the chassis, grounding the shields.
Reece
Reece
Old 07-08-2009, 08:29 AM
pallophotophone pallophotophone is offline
Hi,
If you're particularly attached to this particular set, an isolation transformer rated for 7 amps or so would make it a cold chassis set.
Just a thought..
Bob Hodge
