Old 07-07-2009, 03:17 PM
tlavergne's Avatar
tlavergne tlavergne is offline
Zenith Build Dates
Is there a data base somewhere that I can find out the year my Zenith H845 radio was built?
Thanks,
Tom
Old 07-07-2009, 05:37 PM
The best thing to do is look for date codes on items like the speaker, the filter cap, any original paper caps under the chassis, and on any original Zenith tubes that may remain.
Old 07-07-2009, 06:14 PM
tlavergne's Avatar
Thanks...I will look at those spots.
Old 07-07-2009, 07:33 PM
Tom Bavis's Avatar
Audiophool
Date codes will sometimes be coded like this: 328526. First three digits are the manufacturer - 328 is Utah (speakers). 526 is year (1955 or 65) and week (week26 - end of June). Some dated by quarter - so only used week codes 13, 26, 39, and 52.
Old 07-07-2009, 08:11 PM
tlavergne's Avatar
Stamped into the chassis is 2412297, which I assume is the serial number. Printed on the large speaker is, Zenith and 49CZ883 and 343320. That's all I could find in the radio that wasn't just a part number. Nothing on the tubes, which are all Zenith except for one GE, to indicate a year. So from what you said, Tom, I would assume that the 343 is the speaker manufacturer and the 320 is the year 1953 or 1963 and week 20.
Old 07-08-2009, 08:01 AM
Tom Bavis's Avatar
Audiophool
343 is the code for Zenith Radio. Since the Sams Photofact folder for the 845 is dated 1964, I think we can rule out 1953...
I have the schematic if you need it.
Old 07-08-2009, 12:25 PM
tlavergne's Avatar
Tom,
The schematic would be great...many thanks.
Old 07-08-2009, 07:34 PM
Tom Bavis's Avatar
Audiophool
email for a scan tbavis(at)rochester(dot)rr(dot)com
Old 07-08-2009, 08:11 PM
jeffsod jeffsod is offline
I had one of these and seem to recall finding a date stamped inside somewhere on the case but I maybe confusing that with another set too. But I am almost positive that mine was made in 1960. Not sure how many years they made the 845 but mine was the same as you described in your other post.
