Old 07-12-2009, 01:09 PM
sanford12's Avatar
sanford12 sanford12 is offline
Asbestos heat shields in the first Trans Oceanic's and other early radios
I posted this as a reply to a thread but it's important enough to have it's own thread and maybe should be a sticky.
Be careful there is an asbestos heat shield in the first Trans Oceanic's. I use a respirator and soak the heat shield in polyurethane to encase the asbestos the remove and discard it. Other early radios also have asbestos in them be.
Martin Logan Motion LX16's & B&M 704's
ML Dynamo 300 sub
Outlaw RR2160
Empire 298 TT W/Denon 103 cart
Marantz CD6006, Pioneer DV-588 SACD
Old 07-12-2009, 01:24 PM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
The Devil Inside
The health problems from asbestos came from people who were covered in it all day at work for years, and family members who dealt with their clothing and the asbestos fibers associated with them. A few small sheets of the stuff in an old radio won't hurt much of anything as long as you don't grind it up and snort it.
Growing up leads to growing old and then to dying,
And dying to me dont sound like all that much fun...
-John Mellencamp
Old 07-12-2009, 02:14 PM
sanford12's Avatar
To me it's just not worth the risk. If radios are a hobby and you deal with a lot of early ones and have them in your house prudent precautions are the sensible thing to do for now and for those who will own your radios in the future. You won't have them forever.
ML Dynamo 300 sub
Outlaw RR2160
Old 07-12-2009, 03:42 PM
Rodzilla's Avatar
Rodzilla Rodzilla is offline
as with all things..common sense should prevail...if the asbestos is in a solid form,it's pretty safe,maybe not something you wanna needlessly play around with,but it's not nuclear waste dangerous..it's the airborne dust and fibers that once inhaled cause problems and that you should beware of...if the stuff is fibrous,flaky or easily broken,or likely will be in it's removal or handling,you should probably use some precautions and dispose of it responsibly...but in a solid form as most would be for use in a radio...it's really a pretty low level risk
