Old 07-13-2009, 02:23 PM
Mike3 Mike3 is offline
VK Member
Width Problem with Capehart Model 320
Hello .. this is my first post here .. I have a Capehart model 320 I have been restoring,, and have pretty much fixed all except a width problem.. the crt has a line on the left side... that is wider when you first turn it on and as it warms up 5-10 min the line gets smaller...but never goes away.. and if you try to adjust it out the picture fades and you loose contrast.. I am not a tv repairman.. but I do have a background of self taught electronics,, 30 some odd years,,
I have been posting my progress on the other site.. under capehart 320..the set has been recapped and all tube double checked.. so where should I look for this type problem...
Thanks.. Mike
Old 07-13-2009, 04:08 PM
David Roper's Avatar
console lover
I had the same problem with a Hallicrafters set which was almost impossible to narrow down. It turned out (finally!) to be shorted turns in the width coil.
Old 07-13-2009, 06:50 PM
VK Member
Thanks for replying.. I checked the resistance on the coil and it is as my sams says...
I am using a sub. pix tube in this set and it dosn't use magnetic focus.. and I was told to remove the focus coil.. I don't think they meant me to remove it from the circuit.. but I did .. and now I beleive it changed the B+ .. and may have damaged something,, I had to replace the yoke.. and after replacing it.. I had normal width.. then I heard a popping sound then the line developed on the left side..
any Ideas anyone.. this set is in sams 112-3
Thanks.. Mike
Old 07-16-2009, 04:25 PM
VK Member
Last night I turned off the TV in the dark and noticed the H. Out tube was glowing blue inside.. I replaced it with a new one it also glows blue inside.. could this be a symptom of my width problem?
thanks .. Mike
Old 07-16-2009, 10:40 PM
If it looks like the inside of the glass envelope glowing, that's okay. means that the vacuum is very good inside. Stray electrons hitting the glass, not an issue. Shouldn't be a cause of a width problem.
