Old 10-28-2009, 11:43 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Angry Westinghouse H-196
Since 19 years I am searching for some knobs for the TV-set named above!
I need both channel-knobs (selector/fine tuning) and one of the front knobs.
Help me please not to search 20 years of my life for them.
Thanks in advance,
Old 10-29-2009, 02:24 PM
Can you post close-up photos of what they should look like?
Old 10-29-2009, 03:52 PM
I believe this is the set: http://www.vintagetvsets.com/west196.htm
and http://www.earlytelevision.org/westinghouse_h-196.html
I've seen those brass outer knobs a few times on eBay and swap meets, but don't have any spares for ya right now
I might have some of the inner brown ones though. If you can provide a nice closeup picture, I'll check my stash.
P.S. That's a real nice set
Old 11-02-2009, 05:59 AM
I may have a close-up picture, otherwise I check out what I can do.
Thanks in advance!
Old 11-06-2009, 07:20 AM
Yepp, here is a link to ETF with a clean picture:
It shows the knobs:
And this is mine, you can see, what I need:
Old 11-06-2009, 01:12 PM
Close ups
Here are some close up pictures.
My 196 has three different colors of small knob because that was what I could get, I believe the correct color is the swirled red same as the channel selector.
Complicating matters is that the small knobs fit on two different sized D shafts.
The outer knobs should be Brass clad like the one on the right of picture two but they are available in reverse painted plastic which looks kind of cheap.
