Old 11-13-2009, 06:10 PM
suede's Avatar
suede suede is offline
VK Member
1950 Motorola update
So i finally got my chassis out of my cabinet. Its surprisingly clean, looks good. I did notice a busted 25l6 gt tube, so i replaced it. Plugged it in and.. nothing. All tubes light up, including the back of the crt, but no snow, no light, no nothing on the face of the crt. No idea of where this newbie should go from here.
URL=http://img697.imageshack.us/i/cars017.jpg/][/URL]
Old 11-15-2009, 09:45 PM
To start, have any capacitors been changed? Or is this in "as-found" condition? If the electrolytic caps haven't been changed I would start there. Beyond that...I only come up with more questions. We can work you through it, though.
Old 11-15-2009, 10:01 PM
The power supply is the place to start, and electrolytic capacitors in the p-s are Job Number One. Here is basic advice about replacing capacitors if you haven't done that before:
http://antiqueradio.org/recap.htm
You have the schematic, right? It not only shows how things are connected, but usually has a voltage chart that's very helpful in diagnosing problems like this. Without a schematic, you're shooting in the dark.
